Hi Yimei,
The problem is with how you included asSupport.dbd. There are 2 different mechanisms for construction an application dbd file.
One is to do it in the Makefile, which you tried to do with this line:
testAsynPortDriver_DBD += asSupport.dbd
The other mechanism is to have an XXXAppInclude.dbd file, which is what testAsynPortDriver uses. That is this file:
corvette:asyn/testAsynPortDriverApp/src>more testAsynPortDriverInclude.dbd
include "base.dbd"
include "asyn.dbd"
registrar("testAsynPortDriverRegister")
You need to add this line to that file:
include "asSupport.dbd"
From: Tech-talk <[email protected]> on behalf of 周逸媚 via Tech-talk <[email protected]>
Sent: Tuesday, June 20, 2023 3:36 AM
To: [email protected] <[email protected]>
Subject: autosave Command xxx not found.
I have the same question as :https://epics.anl.gov/tech-talk/2023/msg00603.php
I have compiled autosave and added the connection in the following file.
But it still reports an error:
set_requestfile_path(".")
st.cmd line 17: Command set_requestfile_path not found.
set_savefile_path("/home/EPICS/","autosave")
st.cmd line 18: Command set_savefile_path not found.
save_restoreSet_IncompleteSetsOk(1)
st.cmd line 19: Command save_restoreSet_IncompleteSetsOk not found.
save_restoreSet_DatedBackupFiles(0)
st.cmd line 20: Command save_restoreSet_DatedBackupFiles not found.
set_pass0_restoreFile("shineioc.sav")
st.cmd line 21: Command set_pass0_restoreFile not found.
cas WARNING: Configured TCP port was unavailable.
cas WARNING: Using dynamically assigned TCP port 40981,
cas WARNING: but now two or more servers share the same UDP port.
cas WARNING: Depending on your IP kernel this server may not be
cas WARNING: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
create_monitor_set("shineioc.req",10,"P=SHINE-BI:")
st.cmd line 26: Command create_monitor_set not found.
st.cmd:
dbLoadDatabase("../../dbd/testAsynPortDriver.dbd")
testAsynPortDriver_registerRecordDeviceDriver(pdbbase)
testAsynPortDriverConfigure("testAPD", 1000)
dbLoadRecords("../../db/testAsynPortDriver.db","P=SHINE-BI:,R=,PORT=testAPD,ADDR=0,TIMEOUT=10000")
dbLoadRecords("../../db/asynRecord.db","P=SHINE-BI:,R=,PORT=testAPD,ADDR=0,OMAX=,IMAX=")
asynSetTraceIOMask("testAPD",0,0x2)
iocInit()
xxx/configure/RELEASE:
#RELEASE Location of external products
SUPPORT=/home/EPICS/support
-include $(TOP)/../configure/SUPPORT.$(EPICS_HOST_ARCH)
# IPAC is only necessary if support for Greensprings IP488 is required
# IPAC release V2-7 or later is required.
#IPAC=$(SUPPORT)/ipac-2-15
# SEQ is required for testIPServer
#SNCSEQ=$(SUPPORT)/seq-2-2-5
# EPICS_BASE 3.14.6 or later is required
EPICS_BASE=/home/EPICS/base-7.0.7
ASYN=/home/EPICS/asyn4-38
AUTOSAVE=/home/EPICS/support/autosave-R5-10-2
-include $(TOP)/../configure/EPICS_BASE.$i(EPICS_HOST_ARCH)
-include $(TOP)/../RELEASE.local
-include $(TOP)/../RELEASE.$(EPICS_HOST_ARCH).local
-include $(TOP)/configure/RELEASE.local
xxx/src/Makefile:
TOP=../..
include $(TOP)/configure/CONFIG
# ADD MACRO DEFINITIONS AFTER THIS LINE
DBD += testAsynPortDriver.dbd
LIBRARY_IOC += testAsynPortDriverSupport
testAsynPortDriverSupport_SRCS += testAsynPortDriver.cpp
testAsynPortDriverSupport_LIBS += asyn
testAsynPortDriverSupport_LIBS += $(EPICS_BASE_IOC_LIBS)
PROD_IOC += testAsynPortDriver
# <name>_registerRecordDeviceDriver.cpp will be created from <name>.dbd
testAsynPortDriver_SRCS_DEFAULT += testAsynPortDriver_registerRecordDeviceDriver.cpp testAsynPortDriverMain.cpp
testAsynPortDriverVx_SRCS_vxWorks += testAsynPortDriver_registerRecordDeviceDriver.cpp
testAsynPortDriver_LIBS += testAsynPortDriverSupport asyn
testAsynPortDriver_LIBS += $(EPICS_BASE_IOC_LIBS)
testAsynPortDriver_LIBS += autosave
testAsynPortDriver_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
include $(TOP)/configure/RULES
# ADD RULES AFTER THIS LINE
Best Regards,
Yimei
- autosave Command xxx not found. 周逸媚 via Tech-talk
time delayed using express3 lynn via Tech-talk
starting IOC with systemd David A. Slimmer via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
