Hi, I met some question about the expess3. 1) There is time delay(about 4000ms) except the first run start. 2) Usually, acquires could not stop automatic when time arrived, including the first run. And i did use internal mode. I think both of the reason was about time delay. because the message from st.cmd(the bottom of the mail). Could someone do me a favor. And answer was appreciate. Too mayn message, so I marked some place red which i think important. [xspress3@xspress3 ~]$ xspress3-ioc.sh # This file was automatically generated on Mon 15 Dec 2014 18:37:13 GMT from # source: /home/npr78/diamond/support/xspress3/etc/makeIocs/example1Channel.xml # *** Please do not edit this file: edit the source file instead. *** cd "/usr/lib/epics/iocBoot/xspress3/example1Channel" epicsEnvSet "EPICS_CA_MAX_ARRAY_BYTES", '6000000' epicsEnvSet "EPICS_TS_MIN_WEST", '0' # Loading libraries # ----------------- # Device initialisation # --------------------- cd "/usr/lib/epics/iocBoot/xspress3/example1Channel" dbLoadDatabase "dbd/example1Channel.dbd" example1Channel_registerRecordDeviceDriver(pdbbase) callbackSetQueueSize(4000) ################################################## # Start Xspress3 driver # Parameters # portName The Asyn port name to use # numChannels The max number of channels (eg. 8) # numCards The number of Xspress3 systems (normally 1) # baseIP The base address used by the Xspress3 1Gig and 10Gig interfaces (eg. "192.168.0.1") # Max Frames Used for XSPRESS3 API Configuration (depends on Xspress3 firmware config). # Max Driver Frames Used to limit how big EPICS driver arrays are). Needs to match database MAX_FRAMES_DRIVER_RBV. # maxSpectra The maximum size of each spectra (eg. 4096) # maxBuffers Used by asynPortDriver (set to -1 for unlimited) # maxMemory Used by asynPortDriver (set to -1 for unlimited) # debug This debug flag is passed to xsp3_config in the Xspress API (0 or 1) # simTest 0 or 1. Set to 1 to run up this driver in simulation mode. xspress3Config("XSP3", 1, 1, "192.168.0.1", 16384, 16384, 4096, 4096, 0, 0, 0 ) Simulation: 0 # NDAttrConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory, priority, stackSize, maxTimeSeries, attrName) NDAttrConfigure("XSP3.C1_SCA0", 4096, 0, "XSP3", 0, -1, -1, 0,0, 16384, "CHAN1SCA0" ) # NDAttrConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory, priority, stackSize, maxTimeSeries, attrName) NDAttrConfigure("XSP3.C1_SCA1", 4096, 0, "XSP3", 0, -1, -1, 0,0, 16384, "CHAN1SCA1" ) # NDAttrConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory, priority, stackSize, maxTimeSeries, attrName) NDAttrConfigure("XSP3.C1_SCA2", 4096, 0, "XSP3", 0, -1, -1, 0,0, 16384, "CHAN1SCA2" ) # NDAttrConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory, priority, stackSize, maxTimeSeries, attrName) NDAttrConfigure("XSP3.C1_SCA3", 4096, 0, "XSP3", 0, -1, -1, 0,0, 16384, "CHAN1SCA3" ) Data readout thread PID: 31234 # NDAttrConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory, priority, stackSize, maxTimeSeries, attrName) NDAttrConfigure("XSP3.C1_SCA4", 4096, 0, "XSP3", 0, -1, -1, 0,0, 16384, "CHAN1SCA4" ) Data readout thread TID syscall(SYS_gettid): 31242 # NDAttrConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory, priority, stackSize, maxTimeSeries, attrName) NDAttrConfigure("XSP3.C1_SCA5", 4096, 0, "XSP3", 0, -1, -1, 0,0, 16384, "CHAN1SCA5" ) # NDAttrConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory, priority, stackSize, maxTimeSeries, attrName) NDAttrConfigure("XSP3.C1_SCA6", 4096, 0, "XSP3", 0, -1, -1, 0,0, 16384, "CHAN1SCA6" ) # NDAttrConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory, priority, stackSize, maxTimeSeries, attrName) NDAttrConfigure("XSP3.C1_SCA7", 4096, 0, "XSP3", 0, -1, -1, 0,0, 16384, "CHAN1SCA7" ) # NDAttrConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory, priority, stackSize, maxTimeSeries, attrName) NDAttrConfigure("XSP3.C1_ROI1", 4096, 0, "XSP3", 0, -1, -1, 0,0, 16384, "CHAN1ROI1" ) # NDAttrConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory, priority, stackSize, maxTimeSeries, attrName) NDAttrConfigure("XSP3.C1_ROI2", 4096, 0, "XSP3", 0, -1, -1, 0,0, 16384, "CHAN1ROI2" ) # NDAttrConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory, priority, stackSize, maxTimeSeries, attrName) NDAttrConfigure("XSP3.C1_ROI3", 4096, 0, "XSP3", 0, -1, -1, 0,0, 16384, "CHAN1ROI3" ) # NDAttrConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory, priority, stackSize, maxTimeSeries, attrName) NDAttrConfigure("XSP3.C1_ROI4", 4096, 0, "XSP3", 0, -1, -1, 0,0, 16384, "CHAN1ROI4" ) # NDAttrConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory, priority, stackSize, maxTimeSeries, attrName) NDAttrConfigure("XSP3.C1_ROI5", 4096, 0, "XSP3", 0, -1, -1, 0,0, 16384, "CHAN1ROI5" ) # NDAttrConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory, priority, stackSize, maxTimeSeries, attrName) NDAttrConfigure("XSP3.C1_ROI6", 4096, 0, "XSP3", 0, -1, -1, 0,0, 16384, "CHAN1ROI6" ) # NDAttrConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory, priority, stackSize, maxTimeSeries, attrName) NDAttrConfigure("XSP3.C1_ROI7", 4096, 0, "XSP3", 0, -1, -1, 0,0, 16384, "CHAN1ROI7" ) # NDAttrConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory, priority, stackSize, maxTimeSeries, attrName) NDAttrConfigure("XSP3.C1_ROI8", 4096, 0, "XSP3", 0, -1, -1, 0,0, 16384, "CHAN1ROI8" ) # NDAttrConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory, priority, stackSize, maxTimeSeries, attrName) NDAttrConfigure("XSP3.C1_ROI9", 4096, 0, "XSP3", 0, -1, -1, 0,0, 16384, "CHAN1ROI9" ) # NDAttrConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory, priority, stackSize, maxTimeSeries, attrName) NDAttrConfigure("XSP3.C1_ROI10", 4096, 0, "XSP3", 0, -1, -1, 0,0, 16384, "CHAN1ROI10" ) # NDAttrConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory, priority, stackSize, maxTimeSeries, attrName) NDAttrConfigure("XSP3.C1_ROI11", 4096, 0, "XSP3", 0, -1, -1, 0,0, 16384, "CHAN1ROI11" ) # NDAttrConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory, priority, stackSize, maxTimeSeries, attrName) NDAttrConfigure("XSP3.C1_ROI12", 4096, 0, "XSP3", 0, -1, -1, 0,0, 16384, "CHAN1ROI12" ) # NDAttrConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory, priority, stackSize, maxTimeSeries, attrName) NDAttrConfigure("XSP3.C1_ROI13", 4096, 0, "XSP3", 0, -1, -1, 0,0, 16384, "CHAN1ROI13" ) # NDAttrConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory, priority, stackSize, maxTimeSeries, attrName) NDAttrConfigure("XSP3.C1_ROI14", 4096, 0, "XSP3", 0, -1, -1, 0,0, 16384, "CHAN1ROI14" ) # NDAttrConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory, priority, stackSize, maxTimeSeries, attrName) NDAttrConfigure("XSP3.C1_ROI15", 4096, 0, "XSP3", 0, -1, -1, 0,0, 16384, "CHAN1ROI15" ) # NDAttrConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory, priority, stackSize, maxTimeSeries, attrName) NDAttrConfigure("XSP3.C1_ROI16", 4096, 0, "XSP3", 0, -1, -1, 0,0, 16384, "CHAN1ROI16" ) # NDROIConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory) NDROIConfigure("XSP3.ROI1", 4096, 0, "XSP3", 0, -1, -1) # NDROIConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory) NDROIConfigure("XSP3.ROISUM1", 4096, 0, "XSP3.PROC", 0, -1, -1) 2023/06/20 13:07:14.408 NDPluginDriver::connectToArrayPort Error calling pasynManager->connectDevice to array port XSP3.PROC address 0, status=3, error=asynManager:connectDevice port XSP3.PROC not found # I do not know whether the red error is important.# NDStdArraysConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxMemory) NDStdArraysConfigure("XSP3.ARR1", 4096, 0, "XSP3.ROI1", 0, -1) # NDStdArraysConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxMemory) NDStdArraysConfigure("XSP3.ARRSUM1", 4096, 0, "XSP3.ROISUM1", 0, -1) # NDProcessConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory) NDProcessConfigure("XSP3.PROC", 16, 0, "XSP3", 0, 50, 0) # NDROIConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxBuffers, maxMemory) NDROIConfigure("XSP3.ROIDATA", 16, 0, "XSP3", 0, 50, 0) # NDFileHDF5Configure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr) NDFileHDF5Configure("XSP3.HDF5", 16, 0, "XSP3.ROIDATA", 0) # Final ioc initialisation # ------------------------ cd "/usr/lib/epics/iocBoot/xspress3/example1Channel" dbLoadRecords('db/example1Channel_expanded.db', "XSPRESS3_PREFIX=XSPRESS3-EXAMPLE,TODFORMAT=%d.%m.%Y %H:%M:%S") # there is some error here, then i added the red part, error gone. iocInit Starting iocInit ############################################################################ ## EPICS R3.15.3 $Date: Sun 2015-11-22 17:54:12 +0100$ ## EPICS Base built Jan 11 2018 ############################################################################ iocRun: All initialization complete #Set up some of the more complicated HDF PVs dbpf("XSPRESS3-EXAMPLE:HDF5:FileTemplate", "%s%s%d.hdf5") DBR_CHAR[12]: "%s%s%d.hdf5" dbpf("XSPRESS3-EXAMPLE:HDF5:FileWriteMode", "Stream") DBR_STRING: "Stream" dbpf("XSPRESS3-EXAMPLE:HDF5:EnableCallbacks", "Enable") DBR_STRING: "Enable" #Set up the PROC plugin spectra summing dbpf("XSPRESS3-EXAMPLE:PROC:EnableFilter", "Enable") DBR_STRING: "Enable" dbpf("XSPRESS3-EXAMPLE:PROC:FilterType", "Sum") DBR_STRING: "Sum" dbpf("XSPRESS3-EXAMPLE:PROC:EnableCallbacks", "Enable") DBR_STRING: "Enable" # Enable spectra for channel 1 dbpf("XSPRESS3-EXAMPLE:C1_PluginControlVal", "Enabled") DBR_STRING: "Enabled" #Set up the ROI parameters dbpf("XSPRESS3-EXAMPLE:ROIDATA:EnableX", "Enable") DBR_STRING: "Enable" dbpf("XSPRESS3-EXAMPLE:ROIDATA:EnableY", "Enable") DBR_STRING: "Enable" #Set the default energy and channel range for the ROIDATA plugin. dbpf("XSPRESS3-EXAMPLE:ROIDATA:SizeX", "4096") DBR_LONG: 4096 0x1000 dbpf("XSPRESS3-EXAMPLE:ROIDATA:SizeY", "1") DBR_LONG: 1 0x1 # Xspress 3 configuration dbpf("XSPRESS3-EXAMPLE:CONFIG_PATH", "/etc/epics/xspress3/settings/1channel") DBR_CHAR[38]: "/etc/epics/xspress3/settings/1channel" dbpf("XSPRESS3-EXAMPLE:RUN_FLAGS","0") DBR_STRING: "SCALERS & HIST" dbpf("XSPRESS3-EXAMPLE:NUM_CHANNELS","1") DBR_LONG: 1 0x1 dbpf("XSPRESS3-EXAMPLE:NumImages", "1") DBR_LONG: 1 0x1 # hdf5 output dbpf("XSPRESS3-EXAMPLE:HDF5:FilePath","/home/xspress3/data") DBR_CHAR[20]: "/home/xspress3/data" dbpf("XSPRESS3-EXAMPLE:HDF5:FileName","test") DBR_CHAR[5]: "test" dbpf("XSPRESS3-EXAMPLE:ArrayCallbacks","Enable") DBR_STRING: "Enable" dbpf("XSPRESS3-EXAMPLE:ROIDATA:EnableCallbacks","Enable") DBR_STRING: "Enable" # connect to Xspress3 dbpf("XSPRESS3-EXAMPLE:CONNECT","1") DBR_STRING: "Connect" # set TTL trigger # dbpf("XSPRESS3-EXAMPLE:TriggerMode","TTL Veto Only") dbpf("XSPRESS3-EXAMPLE:TriggerMode","Internal") DBR_STRING: "Internal" dbpf("XSPRESS3-EXAMPLE:ROI1:EnableX", "Enable") DBR_STRING: "Enable" dbpf("XSPRESS3-EXAMPLE:ROI1:EnableY", "Enable") DBR_STRING: "Enable" dbpf("XSPRESS3-EXAMPLE:ROI1:MinY", "0") DBR_LONG: 0 0x0 dbpf("XSPRESS3-EXAMPLE:ROI1:SizeY", "1") DBR_LONG: 1 0x1 dbpf("XSPRESS3-EXAMPLE:ROISUM1:EnableX", "Enable") DBR_STRING: "Enable" dbpf("XSPRESS3-EXAMPLE:ROISUM1:EnableY", "Enable") DBR_STRING: "Enable" dbpf("XSPRESS3-EXAMPLE:ROISUM1:MinY", "0") DBR_LONG: 0 0x0 dbpf("XSPRESS3-EXAMPLE:ROISUM1:SizeY", "1") DBR_LONG: 1 0x1 dbpf("XSPRESS3-EXAMPLE:C1_PluginControlValExtraROI", "0") debug level 0, dummy_system=0 DBR_STRING: "Disabled" dbpf XSPRESS3-EXAMPLE:NDAttributesFile, data/XSP3.xml DBR_CHAR[14]: "data/XSP3.xml" dbpf("XSPRESS3-EXAMPLE:C1_PluginControlValExtraROI", "0") DBR_STRING: "Disabled" # disable DTC by default dbpf("XSPRESS3-EXAMPLE:CTRL_DTC", "0") DBR_STRING: "Disable" Calculating generation from Revision 0x01021017, major=33, minor=23 => determined generation=2 xsp3_scope_mod_create(name='xsp3_scope0') Initialising hardware registers Initialising hardware BRAM xsp3_format_run: nbins_eng=4096, nbins_aux1=1, nbins_aux2=1, max_num_dets=1 xsp3_format_run: Determined num_tf=16385 config with init: After xsp3_format_run, mem_layout = 01C1C000, numtf_hist=0, scaler_num_tf=16384, scaler_num_tf_fw=2097152 Calling xsp3_get_dma_status_block() Finished xsp3_config_scaler with num_tf=16384 xsp3_clocks_setup_int: Called with card=0, clk_src=16, flags=0x0003 xsp3m_clocks_setup_int: write adc_cont=0x80000000 xsp3_clocks_setup: Measured frequency 80.00 MHz Making null roi as file '/etc/epics/xspress3/settings/1channel/chan0_region4.dat' is Zero length xsp3_read_format: Xspress3mini diag/soft hist buffer size=0 lwords xsp3_read_format: diag_hist=0, nbins_eng=4096, nbins_aux1=1, nbins_aux2=1, num_tf=16384 xsp3_format_run: nbins_eng=4096, nbins_aux1=1, nbins_aux2=1, max_num_dets=1 xsp3_format_run: Determined num_tf=16385 xsp_get_trigger_b status: 0 event width: 6 epics> xsp4_system_start_count_enb: Xsp3Sys[path].run_flags=0xC WARNING : xsp3m_flush_readout_tcp: Timeout after 50 attempts checking for TCP threads busy xsp4_system_start_count_enb: Xsp3Sys[path].run_flags=0xC WARNING : xsp3m_flush_readout_tcp: Timeout after 50 attempts checking for TCP threads busy WARNING : xsp3m_flush_readout_tcp: Timeout after 50 attempts checking for TCP threads busy xsp4_system_start_count_enb: Xsp3Sys[path].run_flags=0xC WARNING : xsp3m_flush_readout_tcp: Timeout after 50 attempts checking for TCP threads busy WARNING : xsp3m_flush_readout_tcp: Timeout after 50 attempts checking for TCP threads busy # i acquire 3 times, first time i stop, the second it stop auto, the last one it fail to stopRegards, Lynn
ANJ, 20 Jun 2023 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
