1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: add fields to an existing record
From: Mark Wolfman via Tech-talk <[email protected]>
To: Wang Xiaoqiang <[email protected]>
Cc: "Delgado, Uriel" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 21 Jun 2023 10:30:23 -0500
Hi, Xiaoqiang.
We also use this field for indicating element absorption edges.
I think you're idea would work. I'll keep it in mind in case my regex
solution proves unworkable.
I think it would require me to put some extra code in the pydm window
to have the QCheckBox state change modify the string.
On Wed, Jun 21, 2023 at 06:20:32AM +0000, Wang Xiaoqiang wrote:
> Hi Mark,
> Every ROI has a description field, e.g. R0NM.
> https://epics-modules.github.io/mca/mcaRecord.html#Region-Of-Interest_Fields
> It is of string type, normally used to indicate element absorption edges.
> I wonder if you can append the ophyd information to it. e.g. “FeK [hinted]"
> Best
> Xiaoqiang
> > On 12 Jun 2023, at 18:25, Wolfman, Mark via Tech-talk <[email protected]> wrote:
> > Hi, tech-talkers.
> > Apologies in advance if parts of this don't make sense, I'm not that familiar with EPICS yet.
> > I'm hoping to add a new region-of-interest field [1] to the MCA records used in an existing IOC for our DXP fluorescence detector.
> > Similar to the other ROI fields, I'd like to have ``20bmxmap4b:mca1.R0BH``.
> > This will be a 'bi' field that doesn't do anything in the IOC, but is used by bluesky/ophyd during staging to determine whether the specific ROI is hinted in bluesky (hence BH for "bluesky hint") [2] and is included in the calculations for summing ROI's across elements. I've added extra records to an IOC before, and so I tried adding this as a record but EPICS complained because my record name included a '.' character.
> > One solution is to add a record like "20bmxmap4b:mca1_R0BH", but this makes the Ophyd part more complicated since the Ophyd MCA support expects the ROI to have a ``.Rn`` prefix and then tries to append the ``BH`` on the end[3]. Adding a record like ``mca1_R0BH`` means I have to re-write the MCA support in ophyd so I'd prefer to use the ``mca1.RnBH`` PVs if I can.
> > The full IOC is available on gitlab, though it's presently a work in progress.
> > Looking forward to hearing any ideas on how to make this work.
> > Thanks,
> > Mark
> > [1] https://epics-modules.github.io/mca/mcaRecord.html#Region-Of-Interest_Fields
> > [2] https://blueskyproject.io/ophyd/user_v1/reference/signals.html#kind
> > [3] https://github.com/bluesky/ophyd/blob/0802c77ec973b0ba9f8554d3bcf3a3001def7f66/ophyd/mca.py#L14
> > [4] https://git.aps.anl.gov/20BM/20bmdxp/-/tree/main/
My work schedule may not be the same as your work schedule. Please
don't feel obligated to respond to this e-mail outside of your normal
work hours.
This message may be signed or encrypted with Pretty Good Privacy (PGP)
key BE1E3158.
https://keys.openpgp.org/vks/v1/by-fingerprint/BB98174E34193EDCEA0F423C457826FCBE1E3158
add fields to an existing record Wolfman, Mark via Tech-talk
Re: add fields to an existing record Wang Xiaoqiang via Tech-talk
Prev: Adding EPICS modules to conda-forge Thorne, Keith via Tech-talk
Next: Re: MVME products discontinuation Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: add fields to an existing record Wang Xiaoqiang via Tech-talk
Next: Is HVCAENx527 Available Online for downloading? Weiwei Lu via Tech-talk
