1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Re: Record process when restore using autosave
To: "epics tech talk" <[email protected]>
Date: Mon, 10 Jul 2023 13:47:46 +0800 (GMT+08:00)
The order doesn't matter. Then I need to set both set_pass0_restoreFile and set_pass1_restoreFile or just need to set set_pass0_restoreFile?
Cheers,
Xuan
-----原始邮件-----
发件人:"Ralph Lange via Tech-talk" <[email protected]>
发送时间:2023-07-09 22:34:46 (星期日)
收件人: "EPICS Tech Talk" <[email protected]>
抄送:
主题: Re: Record process when restore using autosave
On Sun, 9 Jul 2023 at 16:09, Mark Rivers <[email protected]> wrote:
If the order of writing to the hardware does not matter then you can set PINI=1 for each record.
If the order matters, you can use one event record with PINI=YES and EVENT scanning for the many records - their PHAS field settings will determine the order.
Re: Re: Record process when restore using autosave Mark Rivers via Tech-talk
Record process when restore using autosave 吴煊 via Tech-talk
Re: Record process when restore using autosave Ralph Lange via Tech-talk
Re: Re: Record process when restore using autosave 吴煊 via Tech-talk
Prev: Job Opportunities at the Canadian Light Source Gillian Black via Tech-talk
Next: Re: Re: Record process when restore using autosave Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Record process when restore using autosave Ralph Lange via Tech-talk
