1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: RE: AreaDetector: Virtual camera selecting from different hardware cameras
From: "Pearson, Matthew via Tech-talk" <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, "Blomley, Edmund (IBPT)" <edmund.blomley at kit.edu>
Date: Wed, 2 Aug 2023 14:29:20 +0000
If I was doing this today I’d do it the way Mark described below (separate IOC, pvaDriver, dynamically setting the input PV name to the NDPluginPva of each camera), as you get the benefits of using the NTNDArray data type which greatly simplifies client configuration. Also, I would add any processing plugins in the separate IOC, linked to the output of the pvaDriver.
However, if you’re only using channel access then this is a solution I’ve used for years:
Setup a high level camera IOC with a subArray record, such like:
# /// subArray for high level user display.
# /// This has to be as big as the biggest detector
record(subArray, "$(S):Det:Array") {
  field(INP, "$(S):Det:Q1:Array1:ArrayData CP MS")      ß areaDetector stdArray plugin array PV name
  field(FTVL, "LONG")
  field(MALM, "$(MAX_SIZE)")
  field(NELM, "$(MAX_SIZE)")
  field(INDX, "0")
And setup several other records to hold the array size values (if the camera images are different sizes), to use in the client display widget:
# /// Several records to provide the sizes and scale of the array
record(longin, "$(S):Det:ArraySizeX") {
  field(INP, "$(S):Det:Q1:Array1:ArraySize0_RBV CP MS")
record(longin, "$(S):Det:ArraySizeY") {
  field(INP, "$(S):Det:Q1:Array1:ArraySize1_RBV CP MS")
(and more records if you need them)
Then use an mbbo to select which camera you want, and that triggers sseq records that write the INP link field names in each of the records above (including the CP MS link attributes).
The client screen just sees these high level records.
Cheers,
Matt
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Mark Rivers via Tech-talk
Sent: Wednesday, August 2, 2023 8:17 AM
To: tech-talk at aps.anl.gov; Blomley, Edmund (IBPT) <edmund.blomley at kit.edu>
Subject: [EXTERNAL] Re: AreaDetector: Virtual camera selecting from different hardware cameras
Hi Eddy,
Now, as it only makes sense for a single screen to be „active“ at any given time, I wonder if it is possible to set up a virtual camera with AreaDetector which gets the datastream dynamically from one of the hardware cameras (depending on an external PV):
Here are a couple of solutions that just switched where the plugins get their data.  This requires that you run all 3 cameras in the same IOC.
·         If you only want to switch the viewer plugin (NDPluginStdArrays or NDPluginPva) to get its data from the selected camera then just use an sseq record called to write the asyn port name of the selected camera to the NDArrayPort PV of the viewer plugin.
·         If you want to switch all plugins to get their data from the selected camera then load an additional plugin like NDPluginROI.  Configure that ROI plugin to just pass the NDArray unmodified to downstream plugins.  Configure downstream plugins to get their data from the ROI plugin.  Now the sseq record modifies the NDArrayPort PV of the ROI plugin
If you want a separate virtual camera then the following will work with the 3 cameras in separate IOCs, each with its own set of plugins.
·         Configure each camera to have its NDPluginPva get the data from the camera and be enabled
·         Create a fourth IOC that uses pvaDriver that is called CAM:VIRTUAL.
·         The sseq record sets the CAM:VIRTUAL:PvName to the NDPluginPva output of the selected camera, e.g. CAM:SCREEN:01:Pva1:Image.
·         This IOC will get its data from the selected screen.
·         Depending on what machine is hosting the IOCs this solution can add additional network traffic.
From: Tech-talk on behalf of Blomley, Edmund (IBPT) via Tech-talk
Sent: Wednesday, August 2, 2023 5:36 AM
Subject: AreaDetector: Virtual camera selecting from different hardware cameras
Hey,
So let’s assume we have an injector with a couple of fluorescent screens which can be moved in and out of the beam path. Each screen has its own camera, integrated via AreaDetector:
- CAM:SCREEN:01
- CAM:SCREEN:02
- CAM:SCREEN:03
- CAM:VIRTUAL:
So that depending on which screen is active, CAM:VIRTUAL: will get the camera data from either CAM:SCREEN:01 or 02 or 03.
Cheers
Eddy
Re: AreaDetector: Virtual camera selecting from different hardware cameras Mark Rivers via Tech-talk
Prev: Re: epics-debhelper Ralph Lange via Tech-talk
Next: Re: Visual Studio code epics-base configure files are gone Lorelli, Jeremy J via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Re: AreaDetector: Virtual camera selecting from different hardware cameras Mark Rivers via Tech-talk
Next: Visual Studio code epics-base configure files are gone Heinz Junkes via Tech-talk
ANJ, 02 Aug 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
