1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Visual Studio code epics-base configure files are gone
From: "Lorelli, Jeremy J via Tech-talk" <[email protected]>
To: Heinz Junkes via Tech-talk <[email protected]>, Heinz Junkes <[email protected]>
Date: Wed, 2 Aug 2023 18:15:54 +0000
Hi Heinz,
It seems like the makefile plugin for vscode is broken with EPICS, it also deletes those files for me. I recommend using either the Microsoft C/C++ extension or
the clangd extension found here. In my experience the clangd extension is faster and has some useful integrations with clang-tidy and clang-format.
These extensions require you to generate a compile_commands.json for the project you're working on. This can be done using a utility such as bear, ex: make clean && bear -- make -j$(nproc)
With the clangd plugin, you'll have to compile EPICS with clang when doing this, otherwise some #errors get hit in compilerSpecific.h
I think you are able to manually set compiler flags with Microsoft's C/C++ extension if the compile_commands.json generation doesn't work out.
- Jeremy
From: Tech-talk <[email protected]> on behalf of Heinz Junkes via Tech-talk <[email protected]>
Sent: Wednesday, August 2, 2023 6:05 AM
Subject: Visual Studio code epics-base configure files are gone
Hallo,
I'm also trying to get to grips with modern things like IDEs (I seem to do this every summer,
but always fail and continue to use the vi).
Now it is Visual Studio code's turn (there is now a Makefile-tool extension available).
My problem:
When I load epics-base (with git clone --recursive, which I can't do with VisualStudio code either)
in the terminal and then create the link with Add Folder to Workspace in VisualCode Studio, I end up with this:
(base) hactar:epics-base junkes$ git status
On branch 7.0
Your branch is up to date with 'origin/7.0'.
Changes not staged for commit:
  (use "git add/rm <file>..." to update what will be committed)
  (use "git restore <file>..." to discard changes in working directory)
        deleted:    configure/CONFIG.gnuCommon
        deleted:    configure/CONFIG_ADDONS
        deleted:    configure/CONFIG_BASE
        deleted:    configure/CONFIG_BASE_VERSION
        deleted:    configure/CONFIG_COMMON
        deleted:    configure/CONFIG_FILE_TYPE
        deleted:    configure/CONFIG_SITE
        deleted:    configure/RELEASE
        deleted:    configure/RULES
        deleted:    configure/RULES.Db
        deleted:    configure/RULES_BUILD
        deleted:    configure/RULES_COMMON
        deleted:    configure/RULES_EXPAND
        deleted:    configure/RULES_FILE_TYPE
        deleted:    configure/os/CONFIG.Common.UnixCommon
        deleted:    configure/os/CONFIG.Common.darwin-x86
        deleted:    configure/os/CONFIG.UnixCommon.Common
        deleted:    configure/os/CONFIG.darwin-x86.Common
        deleted:    configure/os/CONFIG.darwinCommon.darwinCommon
        deleted:    configure/os/CONFIG_SITE.Common.darwin-x86
        deleted:    configure/os/CONFIG_SITE.darwin-x86.Common
        deleted:    configure/os/CONFIG_SITE.darwinCommon.darwinCommon
no changes added to commit (use "git add" and/or "git commit -a”)
I.e. VisualStudio deletes these files? I really don't understand what I'm doing wrong.
I am starting to fear that these tools and I are not compatible :-(
Heinz
Fritz-Haber-Institut    | Phone:         (+49 30) 8413-4270
Heinz Junkes             | Fax (G3+G4):   (+49 30) 8413-5900
Faradayweg 4-6        | VC: https://zoom.fhi.berlin/junkes
D - 14195 Berlin        | E-Mail:        [email protected]
Visual Studio code epics-base configure files are gone Heinz Junkes via Tech-talk
Prev: RE: AreaDetector: Virtual camera selecting from different hardware cameras Pearson, Matthew via Tech-talk
Next: Requesting SDD Detector driver for Skyray spectrometer Manny Mathuthu via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Visual Studio code epics-base configure files are gone Heinz Junkes via Tech-talk
