1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: PowerPMAC pmacAsynCoord
From: "Hidas, Dean via Tech-talk" <[email protected]>
Date: Wed, 16 Aug 2023 12:54:16 +0000
Greetings EPICS Experts,
I’m currently trying to use pmacAsynCoord with the power pmac (pmac-2-5-20 from https://github.com/dls-controls/pmac), which I’ve used successfully on the turbo many times.  When calling pmacAsynCoordCreate() I get a spew of errors of the form:
2023/08/16 08:45:37.298 drvPmacAxisGetStatus: not all status values returned. Status: 0
Command :&2??
Response:
$0000780000060001
$0000780000060001
This is the same output as I get from the controller.  I’m not so experienced with the Power version and am wondering if I may just be missing some pmac setting or if there is something else I may be misconfiguring.  Any advice is much appreciated.  My st.cmd is below.
Best Regards,
-Dean Hidas
#!../../bin/linux-x86_64/IVU18
< envPaths
epicsEnvSet("PMAC1_IP", "192.168.0.200")
epicsEnvSet("sys", "SR:C09-ID:G1")
epicsEnvSet("dev", "IVU18:1")
epicsEnvSet("STREAM_PROTOCOL_PATH", "/usr/lib/epics/protocol:$(TOP)/proto")
cd "${TOP}"
dbLoadDatabase "dbd/IVU18.dbd"
IVU18_registerRecordDeviceDriver pdbbase
# Create SSH Port (PortName, IPAddress, Username, Password, Priority, DisableAutoConnect, noProcessEos)
drvAsynPowerPMACPortConfigure("BRICK1port", $(PMAC1_IP), "root", "deltatau", "0", "0", "0")
# Configure Model 3 Controller Driver (ControlerPort, LowLevelDriverPort, Address, Axes, MovingPoll, IdlePoll)
pmacCreateController("Brick", "BRICK1port", 0, 8, 100, 1000)
# Configure Model 3 Axes Driver (Controler Port, Axis Count)
pmacCreateAxes("Brick", 8)
# Create CS (ControllerPort, Addr, CSNumber, CSRef, Prog)
# Gap: Coordinate System 2 | PROG 2
pmacAsynCoordCreate("BRICK1port", 0, 2, 0, 2)
# Configure CS (PortName, DriverName, CSRef, NAxes)
drvAsynMotorConfigure("BrickCS2", "pmacAsynCoord", 0, 4)
cd "${TOP}/iocBoot/${IOC}"
iocInit
Dean Andrew Hidas, Ph.D.
Sr. Physicist
Brookhaven National Laboratory
Upton, NY 11973, U.S.A.
Phone: +1 631 344 3568
https://www.bnl.gov/staff/dhidas
RE: PowerPMAC pmacAsynCoord Mercado, Ronaldo (DLSLtd, RAL, LSCI) via Tech-talk
Prev: Re: Is there a maximum threshold plugin for areaDetector? Marco A. Barra Montevechi Filho via Tech-talk
Next: RE: PowerPMAC pmacAsynCoord Mercado, Ronaldo (DLSLtd, RAL, LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: asyn makeSupport.pl doesn't respect configure/RELEASE.local Leblanc, Gregory via Tech-talk
