1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: RE: PowerPMAC pmacAsynCoord
From: "Mercado, Ronaldo \(DLSLtd, RAL, LSCI\) via Tech-talk" <[email protected]>
To: "Hidas, Dean" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 16 Aug 2023 15:43:36 +0000
I can’t explain the error, I am using linux-x86-64, not vxWorks.
Here’s the relevant lines in my startup script:
# Create SSH Port (PortName, IPAddress, Username, Password, Priority, DisableAutoConnect, noProcessEos)
drvAsynPowerPMACPortConfigure("SSHP", "192.168.0.200", "root", "deltatau", "0", "0", "0")
# Configure Model 3 Controller Driver (ControlerPort, LowLevelDriverPort, Address, Axes, MovingPoll, IdlePoll)
pmacCreateController("pwbrick", "SSHP", 0, 4, 100, 1000)
# Configure Model 3 Axes Driver (Controler Port, Axis Count)
pmacCreateAxes("pwbrick", 4)
# Create CS (CSPortName, ControllerPort, CSNumber, ProgramNumber)
pmacCreateCS("PPMAC_1_CS_2", "pwbrick", 2, 10)
# Configure Model 3 CS Axes Driver (CSPortName, CSAxisCount)
pmacCreateCSAxes("PPMAC_1_CS_2", 9)
The dbd and lib entries from pmac and motor in the ioc TS02I-CS-IOC-02App/src/Makefile are
TS02I-CS-IOC-02_DBD += drvAsynIPPort.dbd
TS02I-CS-IOC-02_DBD += drvAsynPowerPMACPort.dbd
TS02I-CS-IOC-02_DBD += motorSupport.dbd
TS02I-CS-IOC-02_DBD += devSoftMotor.dbd
TS02I-CS-IOC-02_DBD += pmacAsynMotorPort.dbd
TS02I-CS-IOC-02_LIBS += pmacAsynMotorPort
TS02I-CS-IOC-02_LIBS += softMotor
TS02I-CS-IOC-02_LIBS += motor
TS02I-CS-IOC-02_LIBS += powerPmacAsynPort
Yes, the coordinate system relies on a position reporting plc, a forward kinematic, a reverse kinematic and a motion program.
This has not changed from pmacAsynCoord
Ronaldo
From: Tech-talk <[email protected]> On Behalf Of Hidas, Dean via Tech-talk
Sent: Wednesday, August 16, 2023 4:15 PM
To: [email protected]
Subject: Re: PowerPMAC pmacAsynCoord
Thank you for your response.  In trying this I may be missing a lib/db?:
pmacCreateCS("BrickCS2", "Brick", 2, 2)
st.cmd line 54: Command pmacCreateCS not found.
I notice in pmac-2-5-20/dbd/pmacAsynMotorPortVxWorks.dbd I see (I am not using VxWorks):
function(pmacCreateCS)
function(pmacCreateCSAxis);
function(pmacCreateCSAxes);
but I do not see them elsewhere in dbd/*.  My src/Makefile is in line with (pmac version):
https://github.com/dls-controls/pmac/blob/dls-master/docs/source/migration.rst
Also, does this rely on a position reporting plc as pmacAsynCoord, so it is looking for something like Coord[2].Q[81]?
Thank you again for the help.
Best,
-Dean
From: Mercado, Ronaldo (DLSLtd,RAL,LSCI) <[email protected]>
Date: Wednesday, August 16, 2023 at 9:23 AM
To: Hidas, Dean <[email protected]>, [email protected] <[email protected]>
I can comment that you don’t need pmacAsynCoord any longer when using the pmac driver.
pmacAsynCoord was a separate module from tpmac, but pmac supports coordinate systems using the built-in
pmacCreateCS and pmacCreateCSAxes
I would be pleased to give you an example that I tested only a few weeks ago – excerpt below:
Ronaldo
Sent: Wednesday, August 16, 2023 1:54 PM
Subject: PowerPMAC pmacAsynCoord
Greetings EPICS Experts,
I’m currently trying to use pmacAsynCoord with the power pmac (pmac-2-5-20 from https://github.com/dls-controls/pmac), which I’ve used successfully on the turbo many times.  When calling pmacAsynCoordCreate() I get a spew of errors of the form:
2023/08/16 08:45:37.298 drvPmacAxisGetStatus: not all status values returned. Status: 0
Command :&2??
Response:
$0000780000060001
$0000780000060001
This is the same output as I get from the controller.  I’m not so experienced with the Power version and am wondering if I may just be missing some pmac setting or if there is something else I may be misconfiguring.  Any advice is much appreciated.  My st.cmd is below.
Best Regards,
-Dean Hidas
#!../../bin/linux-x86_64/IVU18
< envPaths
epicsEnvSet("PMAC1_IP", "192.168.0.200")
epicsEnvSet("sys", "SR:C09-ID:G1")
epicsEnvSet("dev", "IVU18:1")
epicsEnvSet("STREAM_PROTOCOL_PATH", "/usr/lib/epics/protocol:$(TOP)/proto")
cd "${TOP}"
dbLoadDatabase "dbd/IVU18.dbd"
IVU18_registerRecordDeviceDriver pdbbase
drvAsynPowerPMACPortConfigure("BRICK1port", $(PMAC1_IP), "root", "deltatau", "0", "0", "0")
pmacCreateController("Brick", "BRICK1port", 0, 8, 100, 1000)
pmacCreateAxes("Brick", 8)
# Create CS (ControllerPort, Addr, CSNumber, CSRef, Prog)
# Gap: Coordinate System 2 | PROG 2
pmacAsynCoordCreate("BRICK1port", 0, 2, 0, 2)
# Configure CS (PortName, DriverName, CSRef, NAxes)
drvAsynMotorConfigure("BrickCS2", "pmacAsynCoord", 0, 4)
cd "${TOP}/iocBoot/${IOC}"
iocInit
Dean Andrew Hidas, Ph.D.
Sr. Physicist
Brookhaven National Laboratory
Upton, NY 11973, U.S.A.
Phone: +1 631 344 3568
https://www.bnl.gov/staff/dhidas
PowerPMAC pmacAsynCoord Hidas, Dean via Tech-talk
RE: PowerPMAC pmacAsynCoord Mercado, Ronaldo (DLSLtd, RAL, LSCI) via Tech-talk
Re: PowerPMAC pmacAsynCoord Hidas, Dean via Tech-talk
Prev: Re: PowerPMAC pmacAsynCoord Hidas, Dean via Tech-talk
Next: medm question of simDetectorIOC timesir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
