1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: 回覆: EPICS support for PI E-500 piezo controller
From: Chiang, Liang-Chih [江良志] via Tech-talk <[email protected]>
Date: Wed, 20 Sep 2023 07:32:51 +0000
Hello EPICS mates,
I'm trying to control PI E-518 which is the communication interface module of the PI E-500 piezo controller system.
EPICS base: 3.14.12.5
Motor module: 6-11
The folder PIGCS2Src  in Motor module 6-11  seems not support E-518.
So I updated the folder with the newest files from GitHub
https://github.com/epics-motor/motorPIGCS2/tree/master/pigcs2App/src ,
and passed the compiling.
When creating motor record for E-518, it shows two kinds of error messages(excerpted):
2023/09/20 15:02:55.455 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_KP_A to list 0, too many parameters
and
2023/09/20 15:02:55.457 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 94 in list 0, bad index
I don't know how to fix it. Would you provide some suggestions?
The full error messages:
# PI E-518 motor controller is connected via Ethernet,
# at IP address 192.168.2.31, TCP port 50000
drvAsynIPPortConfigure("PIE518", "192.168.2.31:50000", 0, 0, 0)
asynSetTraceMask(PIE518,-1,0x21)   # 0x09, 0x03, 0x01
asynSetTraceIOMask(PIE518,-1,0x1)  # 0x02, 0x01, 0x00
# PI E-518 uses GCS(General Command Set). PI_GCS2_CreateController parameters:
#    (1) portName
#    (2) asynPort
#    (3) numAxes
#    (4) priority
#    (5) stackSize
#    (6) movingPollingRate
#    (7) idlePollingRate
# HFMAB angle
PI_GCS2_CreateController("PIE518-1P", "PIE518", 1, 0, 0, 100, 1000)
2023/09/20 15:02:55.434 read from PIE518: (c) 2016 Physik Instrumente (PI) GmbH & Co. KG, E-518.I3, 119053229, 3.70
PIasynAxis::PIasynAxis() 0: A
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_KI_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_KFF_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_NTCHFR1_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_NTCHFR2_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_NTCHRJT1_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_NTCHRJT2_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_NTCHBDWDT1_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_NTCHBDWDT2_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_RBKP_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_RBKI_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_RBKFF_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_RBNTCHFR1_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_RBNTCHFR2_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_RBNTCHRJT1_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_RBNTCHRJT2_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_RBNTCHBDWDT1_A to list 0, too many parameters
2023/09/20 15:02:55.456 asynPortDriver:createParam: port=PIE518-1P error adding parameter PI_SUP_RBNTCHBDWDT2_A to list 0, too many parameters
# optional PI_Support.db
dbLoadRecords("/blsw/13a/software/epics/3.14.12.5/support/motor-R6-11/db/PI_Support.db","P=27a:,R=PIE518-1P:,PORT=PIE518-1P,ADDR=0,TIMEOUT=1")
# asyn record
dbLoadRecords("/blsw/13a/software/epics/3.14.12.5/support/asyn-4-26/db/asynRecord.db", "P=27a:,R=PIE518-1P:Asyn,PORT=PIE518,ADDR=0,OMAX=256,IMAX=256")
iocInit
2023/09/20 15:02:55.457 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 95 in list 0, bad index
2023/09/20 15:02:55.457 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 96 in list 0, bad index
2023/09/20 15:02:55.457 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 97 in list 0, bad index
2023/09/20 15:02:55.457 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 98 in list 0, bad index
2023/09/20 15:02:55.457 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 99 in list 0, bad index
2023/09/20 15:02:55.457 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 100 in list 0, bad index
2023/09/20 15:02:55.457 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 101 in list 0, bad index
2023/09/20 15:02:55.457 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 102 in list 0, bad index
Starting iocInit
## EPICS R3.14.12.5 $Date: Tue 2015-03-24 09:57:35 -0500$
## EPICS Base built Nov  6 2017
2023/09/20 15:02:55.563 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 94 in list 0, bad index
2023/09/20 15:02:55.563 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 95 in list 0, bad index
2023/09/20 15:02:55.563 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 96 in list 0, bad index
2023/09/20 15:02:55.563 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 97 in list 0, bad index
2023/09/20 15:02:55.563 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 98 in list 0, bad index
2023/09/20 15:02:55.563 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 99 in list 0, bad index
2023/09/20 15:02:55.563 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 100 in list 0, bad index
2023/09/20 15:02:55.563 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 101 in list 0, bad index
2023/09/20 15:02:55.563 asynPortDriver:setDoubleParam: port=PIE518-1P error setting parameter 102 in list 0, bad index
The .cmd file:
#Load motor records
dbLoadTemplate("live/pie518_motors.substitutions")
#Load pseudo motor records
dbLoadTemplate("live/pie518_pseudoMotors.substitutions")
< live/pie518.doAfterIocInit
#    (1) portName
#    (2) asynPort
#    (3) numAxes
#    (4) priority
#    (5) stackSize
# HFMAB angle
dbLoadRecords("$(MOTOR)/db/PI_Support.db","P=27a:,R=PIE518-1P:,PORT=PIE518-1P,ADDR=0,TIMEOUT=1")
# asyn record
dbLoadRecords("$(ASYN)/db/asynRecord.db", "P=27a:,R=PIE518-1P:Asyn,PORT=PIE518,ADDR=0,OMAX=256,IMAX=256")
Best regards.
LiangChih Chiang
NSRRC Beamline group
email:[email protected]
寄件者: Chiang, Liang-Chih [江良志] <[email protected]>
寄件日期: 2023年9月9日 上午 09:49
收件者: Kevin Peterson <[email protected]>; [email protected] <[email protected]>
主旨: 回覆: EPICS support for PI E-500 piezo controller
Thanks Kevin.
I later found out that E-500 is the name of the system.
Its communication interface module is E-518
which is supported by motorPIGCS2 module.
ps. The label "E-518" is not in an obvious place of the E-500 chassis.
Best regards.
LiangChih Chiang
寄件者: Kevin Peterson <[email protected]>
寄件日期: 2023年9月8日 下午 10:37
收件者: Chiang, Liang-Chih [江良志] <[email protected]>; [email protected] <[email protected]>
主旨: Re: EPICS support for PI E-500 piezo controller
The E-500 isn't in the list of supported controllers, but it still may
be supported by the motorPIGCS2 module:
The communication interface card might of the E-500 might report a
different version string in response to the "*IDN?" command, which is
what the motor driver queries:
https://github.com/epics-motor/motorPIGCS2/blob/0a452b905d2754dd774701013de3046e4c1f2f16/pigcs2App/src/PIasynController.cpp#L120
and then uses to determine the controller type:
https://github.com/epics-motor/motorPIGCS2/blob/0a452b905d2754dd774701013de3046e4c1f2f16/pigcs2App/src/PIGCSController.cpp#L43-L109
Kevin
On 9/8/23 01:37, Chiang, Liang-Chih [江良志] via Tech-talk wrote:
> Dear EPICS mates,
> Is there a EPICS support module for PI E-500 piezo controller?
> I can't find it in Support Modules webpage
> https://epics.anl.gov/modules/index.php
> <https://epics.anl.gov/modules/index.php>
> and in PI GitHub
> <https://github.com/epics-motor/motorPI>
> Are there any other PI controller models similar to E-500?
>  From which I can modify the source code of the support module.
> Best regards.
> LiangChih Chiang
> NSRRC
> Beamline Group
EPICS support for PI E-500 piezo controller Chiang, Liang-Chih [江良志] via Tech-talk
Re: EPICS support for PI E-500 piezo controller Kevin Peterson via Tech-talk
回覆: EPICS support for PI E-500 piezo controller Chiang, Liang-Chih [江良志] via Tech-talk
Prev: Re: Streamdevice reads weird 1 byte null data Zimoch Dirk via Tech-talk
Next: Re: Streamdevice reads weird 1 byte null data Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: 回覆: EPICS support for PI E-500 piezo controller Chiang, Liang-Chih [江良志] via Tech-talk
Next: Phoebus Databrowser Florian Feldbauer via Tech-talk
