1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Strange error from pvAccess
To: "[email protected]" <[email protected]>, Jörn Dreyer <[email protected]>
Date: Tue, 24 Oct 2023 12:18:01 +0000
Hi Jörn,
You might want to take a look at the code here which converts between NDArrays and NTNDArrays.
From: Tech-talk <[email protected]> on behalf of Jörn Dreyer via Tech-talk <[email protected]>
Sent: Tuesday, October 24, 2023 7:04 AM
To: [email protected] <[email protected]>
Subject: Strange error from pvAccess
Hello,
I am using pvAccess to read image data from a NDPluginPVA in areaDetector.
When I do the following lines in my program:
PvaClientChannelPtr channel = pva->channel((m_ImagePrefix + *imgDataPV).toStdString().c_str(), m_AccessMethod->toStdString().c_str(), 2.0);
epics::pvData::shared_vector<const double> array = channel->getDoubleArray();
I get an error:
Error: PvaClientData::getDoubleArray() did not find a scalarArray field
m_AccessMethod->toStdString().c_str() returns "pva".
If I use the same code with channel access it works.
Do I have to pass some special string to getDoubleArray in case of NDPluginPVA?
Jörn
Re: Strange error from pvAccess Jörn Dreyer via Tech-talk
Prev: Strange error from pvAccess Jörn Dreyer via Tech-talk
Next: RE: [EXTERNAL] Re: process multiple lines with streamdevice Baily, Scott A via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: Re: Strange error from pvAccess Jörn Dreyer via Tech-talk
