1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Strange error from pvAccess
From: Jörn Dreyer via Tech-talk <[email protected]>
To: "[email protected]" <[email protected]>, Mark Rivers <[email protected]>
Date: Wed, 25 Oct 2023 06:35:51 +0200
Hi Mark,
thanks for the answer.Unfortunately I was not able to figure out how this could solve my problem.
This clas stakes an NTNDArray and can convert it into an NDArray (toArray). One can also put an NDArray into it, but not retrieve an NTNDArray from it
(fromArray). But to make use of it I firs would need to get a handle to the NTNDArray that my PvaClientChannelPtr is connected to.
This class has 4 functions to retrieve data (getDouble, getDoubleArray, getString and getStringArray). There is no way to retrieve an NTNDArray this way.
I thought that PvaClientChannel would take care of the conversion internally but that seems not to be the case. So probably I have to stick with the old NDStdArray.
I am working on a client program that is making use of pvAccess and the qeFramework to retrieve and display data.
Am Dienstag, 24. Oktober 2023, 14:18:01 CEST schrieb Mark Rivers:
> Hi Jörn,
> You might want to take a look at the code here which converts between NDArrays and NTNDArrays.
> https://github.com/areaDetector/ADCore/blob/master/ADApp/ntndArrayConverterSrc/ntndArrayConverter.cpp
> Mark
> ________________________________
> From: Tech-talk <[email protected]> on behalf of Jörn Dreyer via Tech-talk <[email protected]>
> Sent: Tuesday, October 24, 2023 7:04 AM
> To: [email protected] <[email protected]>
> Subject: Strange error from pvAccess
> Hello,
> I am using pvAccess to read image data from a NDPluginPVA in areaDetector.
> When I do the following lines in my program:
> PvaClientChannelPtr channel = pva->channel((m_ImagePrefix + *imgDataPV).toStdString().c_str(), m_AccessMethod->toStdString().c_str(), 2.0);
> epics::pvData::shared_vector<const double> array = channel->getDoubleArray();
> I get an error:
> Error: PvaClientData::getDoubleArray() did not find a scalarArray field
> m_AccessMethod->toStdString().c_str() returns "pva".
> If I use the same code with channel access it works.
> Do I have to pass some special string to getDoubleArray in case of NDPluginPVA?
> Regards,
> Jörn
Dr. Jörn Dreyer
HIBEF DAQ + Controls
Institut für Strahlenpysik
Abt. FWKX
Tel: +49 351 260 3263
Fax: +49 351 260 123263
Helmholtz-Zentrum Dresden - Rossendorf e.V. (HZDR)
Bautzner Landstr. 400 | 01328 Dresden | Germany
Tel: +49 (0) 351 260 1234
http://www.hzdr.de
Vorstand: Prof. Dr. Sebastian M. Schmidt, Dr. Diana Stiller
Vereinsregister: VR 1693 beim Amtsgericht Dresden
Re: Strange error from pvAccess Érico Nogueira Rolim via Tech-talk
Strange error from pvAccess Jörn Dreyer via Tech-talk
Re: Strange error from pvAccess Mark Rivers via Tech-talk
Prev: Re: [EXTERNAL] RTEMS BSP for MVME8100 Heinz Junkes via Tech-talk
Next: Re: PVList in C++ API Eusebio Naif Al-Soliman Fuentes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Strange error from pvAccess Mark Rivers via Tech-talk
Next: Re: Strange error from pvAccess Érico Nogueira Rolim via Tech-talk
