1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Get the type of a PV in C++ API
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Eusebio Naif Al-Soliman Fuentes <[email protected]>
Cc: Tech Talk <[email protected]>
Date: Fri, 3 Nov 2023 11:14:42 -0700
On 11/2/23 04:45, Eusebio Naif Al-Soliman Fuentes via Tech-talk wrote:
Hello everybody.
I have a small question. In the pvaClient library for C++ (https://docs.epics-controls.org/projects/pvaclient-cpp/en/latest/) there are many examples to get the value and other fields of a PV.
However, in order to get the value as a double, like in this example https://github.com/epics-rip/exampleCPP/blob/master/exampleClient/src/examplePvaClientGet.cpp,
Is should point out that this URL is in the "epics-rip" organization, which we use as a final resting place for abandoned code.  Not something I would recommend as a starting point for a new development.
you have to previously know that the PV value is a double. Is there any method to get the type (int, long, double...) of the value field? Something like ->getType().
This was a common pain point in early versions of pvDataCPP API.  Certainly for me, which I why I extended the "intermediate" interface classes PVScalar and PVScalarArray with the getAs() and putFrom() methods to attempt some conversion.  Of course to use these, you will still need to check if a field as a scalar or array of scalars.  (as opposed to a union, sub-structure, variant, or arrays of these same)
Another common "gotcha" to watch out when looking through these obsolete examples are calls to getSubField() which do not check for a returned NULL  An alternate form getSubFieldT() exists which throws an exception instead.
With PVXS, I tried to design the API to avoid these common mistakes and others.
For a longer discussion, see:
https://mdavidsaver.github.io/pvxs/overview.html#comparison-with-pvdatacpp
Thanks in advance.
Saludos/Best regards
University of Granada
MSc. Data Science and Computer Engineering
[email protected]
Get the type of a PV in C++ API Eusebio Naif Al-Soliman Fuentes via Tech-talk
Prev: convert .adl to .opi Pete Jemian via Tech-talk
Next: Re: fanout is not working Tran, Phi Dung via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Get the type of a PV in C++ API Michael Davidsaver via Tech-talk
Next: Linux distribution suggestion for EPICS Vincent van Beveren via Tech-talk
