Subject: |
Re: caget -d DBR_...INT doesn't work |
Ralph Lange via Tech-talk <[email protected]> |
To: |
EPICS Tech Talk <[email protected]> |
Date: |
Thu, 9 Nov 2023 17:52:21 +0100 |
On Wed, 8 Nov 2023 at 19:13, Michael Davidsaver via Tech-talk < [email protected]> wrote: On 11/8/23 05:45, Érico Nogueira Rolim via Tech-talk wrote: >
> This was an inconsistency I noticed in caget. The help output lists
> multiple DBR_...INT types as options for caget's -d option, but none of
> them work, because the dbr_text array from
> modules/ca/src/client/access.cpp includes only DBR_...SHORT strings.
> Would it be okay to simply remove the INT options from the help output
> entirely? Or should the tool try and replace "INT" for "SHORT", similar
> to how it adds "DBR_" when it doesn't find a match at first?
I had not noticed this before. I guess because DOUBLE and LONG are much more common.
Different case, though: DOUBLE and LONG do exist as separate different DBR_ type codes.
> $ caget -d INT some:name
> Requested dbr type out of range or invalid - ignored. ('caget -h' for help.)
Correcting the help message would be a good first step.
I would just silently replace "_INT" by "_SHORT" when reading the argument. Since the _INT tag appears in header files and documentation, we would call for users asking why we don't support INT...
Note that the help message correctly shows the same numerical type for them - it just slipped that "INT" is not valid as the tag string.
Good catch! ~Ralph
- caget -d DBR_...INT doesn't work Érico Nogueira Rolim via Tech-talk
- Re: caget -d DBR_...INT doesn't work Michael Davidsaver via Tech-talk
AW: ADPerkinElmer Bad Pixel Files Sintschuk, Michael via Tech-talk
Re: second relative motion stuck in a do loop Tran, Phi Dung via Tech-talk
<2023>
2025
2026
CS-Studio XY Graph problem with >2046 samples Heesterman, Peter via Tech-talk
<2023>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
