1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: "duty cycle" records
From: Gerrit Kühn via Tech-talk <[email protected]>
To: Ralph Lange via Tech-talk <[email protected]>
Date: Wed, 22 Nov 2023 11:25:06 +0100
Am Wed, 22 Nov 2023 10:07:01 +0100
schrieb Ralph Lange via Tech-talk <[email protected]>:
> - Transparent: use a few calcout records that basically count down,
> initiating actions on "change to zero". More records for the interface as
> needed.
> I would probably go for the database solution, because of the full
> transparency and online modifiable functionality (good when developing).
This sounds indeed like what I would have chosen based on your
description. Sounds less complex than having to learn SNL and all the
mechanics behind it while being more "approachable" while
developing/debugging.
> In case you eventually have a generic database solution, please consider
> posting it to https://github.com/epics-docs/database-examples, which is a
> good place to share such patterns.
Thanks for the pointers. Looks like a simple counter is already there.
I'll see how far I get with this (and certainly be back here when I get
stuck). It would be great if there were more examples/patterns in the git
repo. How would "posting" something work there? Just open an new issue,
come up with a pull request...?
cu
  Gerrit
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: "duty cycle" records Ralph Lange via Tech-talk
"duty cycle" records Gerrit Kühn via Tech-talk
Prev: Re: "duty cycle" records Ralph Lange via Tech-talk
Next: Re: "duty cycle" records Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
