1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: RE: "duty cycle" records
To: Gerrit Kühn <[email protected]>, Ralph Lange via Tech-talk <[email protected]>
Date: Wed, 22 Nov 2023 14:54:45 +0000
Hi Gerrit,
You are missing a way to process the second record.
You can achieve this by providing the PP flag to the OUT link:
  field (OUT, "$(CHAN)_DUTY_TEST PP")
Or by using the FLNK on the calcout record (this will result in DUTY_TEST record processing everytime the calcout record processes).
Best regards,
Žiga
> -----Original Message-----
> From: Tech-talk <[email protected]> On Behalf Of Gerrit Kühn
> via Tech-talk
> Sent: Wednesday, November 22, 2023 3:33 PM
> To: Ralph Lange via Tech-talk <[email protected]>
> Subject: Re: "duty cycle" records
> Am Wed, 22 Nov 2023 11:44:03 +0100
> schrieb Ralph Lange via Tech-talk <[email protected]>:
> > So my description was biased. Yep, that happens.
> But it was perfectly reasonable, all fine. :)
> > Small database is a good approach for your size of problem. On the same
> > IOC is good, as you don't have to handle disconnects.
> I guess I still fail to understand how even the simple things work. I have
> made the following for testing now:
> record (calcout, "$(CHAN)_DUTY_CYC") {
>   field (DESC, "duty cycled output")
>   field (VAL,  "10") # 1st cycle time
>   field (INPA, "10") # cycle time
>   field (CALC, "VAL-1")
>   field (OUT, "$(CHAN)_DUTY_TEST")
>   field (OOPT, "Transition To Zero")
>   field (SCAN, "1 second")
> record (ao, "$(CHAN)_DUTY_TEST") {
>   field (VAL, "11")
> The idea was to have the first channel count down seconds from a given
> value and then write out to a diffreent channel and make that one process.
> The countdown works as expected, I can follow it with camonitor. However,
> it looks like the OOPT is never hit even though the counter goes below
> zero. The second channel never changes and stays at the default value "11",
> it looks like it is never written to. What am I doing wrong?
> cu
>   Gerrit
"duty cycle" records Gerrit Kühn via Tech-talk
Re: "duty cycle" records Ralph Lange via Tech-talk
Re: "duty cycle" records Gerrit Kühn via Tech-talk
Prev: Re: "duty cycle" records Gerrit Kühn via Tech-talk
Next: Re: "duty cycle" records Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
