Subject: |
Re: "duty cycle" records |
Gerrit Kühn via Tech-talk <[email protected]> |
To: |
Date: |
Wed, 22 Nov 2023 17:07:10 +0100 |
Am Wed, 22 Nov 2023 16:23:29 +0100
schrieb Gerrit Kühn via Tech-talk <[email protected]>:
> > You need to put PP at the end of your OUT link to force the second
> > record to process.
> Yes, that was the mssing bit. Thanks to both of you for pointing this out
> to me.
Last question for today (hopefully). I have these records now:
record (calcout, "$(CHAN)_DUTY_CYC") {
field (DESC, "duty cycled output")
field (VAL, "10") # 1st cycle time
field (INPA, "10") # cycle time
field (CALC, "VAL-1")
field (OUT, "$(CHAN)_DUTY_RESET PP")
field (OOPT, "Transition To Zero")
field (SCAN, "1 second")
record (calcout, "$(CHAN)_DUTY_RESET") {
field (DESC, "reset cycle counter")
field (VAL, "11")
field (INPA, "$(CHAN)_DUTY_CYC.INPA")
field (CALC, "A")
field (OUT, "$(CHAN)_DUTY_CYC")
field (SCAN, "Passive")
The second record gets processed when the counter in the first record
reaches zero. However, it only resets the counter as desired when the INPA
field in the second record is defined constant (i.e., INPA, "10" directly
in the second record).
My original idea as written above was to get the INPA field of the second
record from the INPA field of the first record. However, this does not
work. camonitor reports this as "LINK INVALID" although I can use caget on
the reported link just fine (and get the correct value). Again, this feels
like I'm missing a simple thing...
cu
Gerrit
smime.p7s
Description: S/MIME cryptographic signature
- Re: "duty cycle" records Rolf Keitel via Tech-talk
- "duty cycle" records Gerrit Kühn via Tech-talk
- Re: "duty cycle" records Ralph Lange via Tech-talk
- Re: "duty cycle" records Gerrit Kühn via Tech-talk
- Re: "duty cycle" records Mark Rivers via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
