Hi Lewis,
READONLY is a macro which expands to "const" (for compilers which support it, C didn't have that before standardization) , although that macro isn't used inside Base anymore. It's defined in the shareLib.h
header, and since the shareLib.h header isn't being included by most of the Base header files now the macro is no longer being defined as a side-effect of some other includes in that source file.
I would recommend replacing it with "const" in those sources which still use it, now that all our supported compilers do understand that keyword, and sending a PR to the sscan project on GitLab.
- Andrew
Complexity comes for free, Simplicity you have to work for.
Hello, Tech-Talkers!
I'm building synApps 6.2.1 against EPICS Base 7.0.7 on macOS Sonoma
(14.1.1) on Apple Silicon (EPICS_HOST_ARCH=darwin-aarch64), and the
build fails with an error while building sscan; the end of the build
output is below. I'll keep looking into the issue, but since it's not
immediately obvious to me what's wrong, I thought I'd ask here, has
anyone successfully built sscan on this platform?
Thanks!
Lewis
cc -DUSE_TYPED_RSET -DUNIX -Ddarwin -O3 -g -Wall -Werror-implicit-function-declaration -arch arm64 -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/clang -I../../../include/os/Darwin -I../../../include
-I/tmp/build-01/opt/synapps-6.2.1/seq-2-2-9/include -I/tmp/build-01/opt/epics-base-7.0.7/include/compiler/clang -I/tmp/build-01/opt/epics-base-7.0.7/include/os/Darwin -I/tmp/build-01/opt/epics-base-7.0.7/include -c ../saveData_writeXDR.c
../saveData_writeXDR.c:1841:2: error: use of undeclared identifier 'READONLY'
READONLY DBR_VAL * pval = eha.dbr;
../saveData_writeXDR.c:1850:23: error: use of undeclared identifier 'pval'
size= strlen((char*)pval);
../saveData_writeXDR.c:1874:22: error: use of undeclared identifier 'pval'
memcpy(pnode->pval, pval, size);
../saveData_writeXDR.c:1888:2: error: use of undeclared identifier 'READONLY'
../saveData_writeXDR.c:1892:31: error: use of undeclared identifier 'pval'
strncpy(pnode->desc, (char *)pval, MAX_STRING_SIZE);
5 errors generated.
make[4]: *** [saveData_writeXDR.o] Error 1
make[3]: *** [install.darwin-aarch64] Error 2
make[2]: *** [src.install] Error 2
make[1]: *** [sscanApp.install] Error 2
make: *** [/tmp/build-01/opt/synapps-6.2.1/sscan-R2-11-4.install] Error 2
- Re: sscan R2-11-4 build error on macOS Sonoma? J. Lewis Muir via Tech-talk
- sscan R2-11-4 build error on macOS Sonoma? J. Lewis Muir via Tech-talk
RE: RE: EPICS Archiver Appliance and Channel Filters Quemuel, Jonathan Kelii Kenji via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
