1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: sscan R2-11-4 build error on macOS Sonoma?
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Thu, 30 Nov 2023 15:59:13 -0600
On 11/30, Johnson, Andrew N. wrote:
> I would recommend replacing it with "const" in those sources which still use it, now that all our supported compilers do understand that keyword, and sending a PR to the sscan project on GitLab.
Bingo!  You're exactly right.  After making that change, sscan builds
successfully.  Thanks much!  PR at
  https://github.com/epics-modules/sscan/pull/30
And now on to the next failing module. :-)
Lewis
sscan R2-11-4 build error on macOS Sonoma? J. Lewis Muir via Tech-talk
Re: sscan R2-11-4 build error on macOS Sonoma? Johnson, Andrew N. via Tech-talk
Prev: RE: RE: EPICS Archiver Appliance and Channel Filters Quemuel, Jonathan Kelii Kenji via Tech-talk
Next: EPICS vs. EPICS Base consistency on website? J. Lewis Muir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: sscan R2-11-4 build error on macOS Sonoma? Johnson, Andrew N. via Tech-talk
