1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: LabCA for MATLAB Installation error
To: Freddie Akeroyd - STFC UKRI <[email protected]>
Cc: Giovanni Franzini <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 19 Dec 2023 11:44:36 +0100
Dear Freddie and all
I looked a bit more carefully at the errors, and here are some details, unfortunately I am not very skilled in either c/c++ programming or windows programming, so that makes it hard for me to understand what is important.
The setup is:
* Windows 10
* MSYS2 MINGW64 compiler "complex" as recommended for the EPICS part
* Matlab R2022a
* epics-labca-labca_3_8_1
* EPICS version base-3.15.9
In the labca source code I have set
configure/RELEASE
    BASE_SUBDIR=
    EPICS_BASE=/home/boj/base-3.15.9/
    MATLABDIR = /d/Matlab2022a
    MATLIB_SUBDIR=win64/mingw64
In my .bash_profile for MSYS2 I have
    EPICS_HOST_ARCH=windows-x64-mingw
    PATH=${EPICS_BASE}/bin/${EPICS_HOST_ARCH}:${PATH}
EPICS  command line tools works
Included at the end of this mail is the full output of make, but as I understand it the problem is in the linking of mezcaglue.dll
I get:
gcc          -DMATLAB_APP    -D_MINGW -D__USE_MINGW_ANSI_STDIO     -O3   -Wall      -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL    -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/WIN32 -I../../include    -I/home/boj/base-3.15.9/include/compiler/gcc -I/home/boj/base-3.15.9/include/os/WIN32 -I/home/boj/base-3.15.9/include             -I../../ezca -I/d/Matlab2022a/extern/include    -o mglue.obj -c ../mglue.c g++ -o mezcaglue.dll -shared -Wl,--out-implib,libmezcaglue.dll.a -L/home/boj/epics-labca-labca_3_8_1/lib/windows-x64-mingw -L/home/boj/base-3.15.9/lib/windows-x64-mingw /d/Matlab2022a/extern/lib/win64/mingw64/libut.lib /d/Matlab2022a/extern/lib/win64/mingw64/libmx.lib /d/Matlab2022a/extern/lib/win64/mingw64/libmex.lib -m64               ini.obj multiEzca.obj ctrlC-polled.obj gitstring.obj mglue.obj   -lezcamt -lca -lCom  -luser32 -lws2_32 -ladvapi32 -luser32 -lkernel32 -lwinmm
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe
: ini.obj:ini.cc:(.text+0x9b): undefined reference to `mexPrintf_800'
: ini.obj:ini.cc:(.text+0xfe): undefined reference to `mexCallMATLAB_800'
Which then continues with  "undefined reference to `XXXX" for many lines and end with
collect2.exe: error: ld returned 1 exit status
make[2]: *** [/home/boj/base-3.15.9/configure/RULES_BUILD:292: mezcaglue.dll] Error 1 make[2]: Leaving directory '/home/boj/epics-labca-labca_3_8_1/glue/O.windows-x64-mingw' make[1]: *** [/home/boj/base-3.15.9/configure/RULES_ARCHS:58: install.windows-x64-mingw] Error 2
make[1]: Leaving directory '/home/boj/epics-labca-labca_3_8_1/glue'
make: *** [/home/boj/base-3.15.9/configure/RULES_DIRS:85: glue.install] Error 2
I hope this makes sence, and maybe can give a hint to what I am dooing wrong.
Best regards
    Bo
Full output of make:
boj@dk1080799 MINGW64 ~/epics-labca-labca_3_8_1
$ make
make: git: No such file or directory
make -C ./configure install
make[1]: Entering directory '/home/boj/epics-labca-labca_3_8_1/configure'
perl -CSD /home/boj/base-3.15.9/bin/windows-x64-mingw/makeMakefile.pl O.windows-x64-mingw ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.windows-x64-mingw -f ../Makefile TOP=../.. \
    T_A=windows-x64-mingw install
make[2]: Entering directory '/home/boj/epics-labca-labca_3_8_1/configure/O.windows-x64-mingw' perl -CSD /home/boj/base-3.15.9/bin/windows-x64-mingw/convertRelease.pl checkRelease
echo MEXEXT=.mexw64 >>MATLAB_CONFIG_INCLUDE
make[2]: Leaving directory '/home/boj/epics-labca-labca_3_8_1/configure/O.windows-x64-mingw'
make[1]: Leaving directory '/home/boj/epics-labca-labca_3_8_1/configure'
make -C ./ezca install
make[1]: Entering directory '/home/boj/epics-labca-labca_3_8_1/ezca'
make[2]: Entering directory '/home/boj/epics-labca-labca_3_8_1/ezca/O.windows-x64-mingw' gcc             -D_MINGW -D__USE_MINGW_ANSI_STDIO     -O3 -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/WIN32 -I../../include -I/home/boj/base-3.15.9/include/compiler/gcc -I/home/boj/base-3.15.9/include/os/WIN32 -I/home/boj/base-3.15.9/include                  -MM -MF ezca.d -MT ezca.obj ../ezca.c gcc             -D_MINGW -D__USE_MINGW_ANSI_STDIO     -O3 -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/WIN32 -I../../include -I/home/boj/base-3.15.9/include/compiler/gcc -I/home/boj/base-3.15.9/include/os/WIN32 -I/home/boj/base-3.15.9/include                 -o ezca.obj -c ../ezca.c
../ezca.c: In function 'ezcaLock':
../ezca.c:89:25: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
   89 |                         (unsigned long)epicsThreadGetIdSelf()); \
../ezca.c:570:9: note: in expansion of macro 'EZCA_LOCK'
  570 |         EZCA_LOCK();
../ezca.c: In function 'ezcaUnlock':
../ezca.c:575:9: note: in expansion of macro 'EZCA_LOCK'
  575 |         EZCA_LOCK();
../ezca.c: In function 'ezcaPollCbInstall':
../ezca.c:612:9: note: in expansion of macro 'EZCA_LOCK'
  612 |         EZCA_LOCK();
../ezca.c:611:1: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
  611 | if ( (i=Initialized) )
../ezca.c:614:9: note: ...this statement, but the latter is misleadingly indented as if it were guar
ded by the 'if'
  614 |         rval = pollCb;
../ezca.c:97:25: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
   97 |                         (unsigned long)epicsThreadGetIdSelf()); \
../ezca.c:618:9: note: in expansion of macro 'EZCA_UNLOCK'
  618 |         EZCA_UNLOCK();
../ezca.c:617:1: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
  617 | if (i)
../ezca.c:620:9: note: ...this statement, but the latter is misleadingly indented as if it were guar
ded by the 'if'
  620 |         return rval;
../ezca.c: In function 'ezcaEndGroupWithReport':
../ezca.c:713:33: note: in expansion of macro 'EZCA_LOCK'
  713 |                                 EZCA_LOCK(); /* make *sure* mutex is not relinquished by add
ing a nest count */
../ezca.c:715:33: note: in expansion of macro 'EZCA_UNLOCK'
  715 |                                 EZCA_UNLOCK();
../ezca.c:966:13: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
  966 |             if (Trace || Debug)
../ezca.c:104:29: note: ...this statement, but the latter is misleadingly indented as if it were gua
rded by the 'if'
  104 | #define MARK_OUTSTANDING(n) do { if ( (ezcaOutstanding = (n)) ) ca_flush_io(); } while (0)
../ezca.c:969:17: note: in expansion of macro 'MARK_OUTSTANDING'
  969 |                 MARK_OUTSTANDING(needs_work);
../ezca.c:1063:29: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
 1063 |                             if (AutoErrorMessage)
../ezca.c:1066:33: note: ...this statement, but the latter is misleadingly indented as if it were gu
arded by the 'if'
 1066 |                                 if ( MONBLOCK == wp->worktype && wp->pval )
../ezca.c: In function 'prologue':
../ezca.c:4905:9: note: in expansion of macro 'EZCA_LOCK'
 4905 |         EZCA_LOCK();
../ezca.c: In function 'epilogue':
../ezca.c:4934:9: note: in expansion of macro 'EZCA_UNLOCK'
 4934 |         EZCA_UNLOCK();
../ezca.c: In function 'EzcaClearChannel':
../ezca.c:5032:9: note: in expansion of macro 'EZCA_UNLOCK'
 5032 |         EZCA_UNLOCK();
../ezca.c:5034:9: note: in expansion of macro 'EZCA_LOCK'
 5034 |         EZCA_LOCK();
../ezca.c: In function 'EzcaPendEvent':
../ezca.c:5519:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
 5519 |     if (Trace || Debug)
../ezca.c:5522:9: note: ...this statement, but the latter is misleadingly indented as if it were gua
rded by the 'if'
 5522 |         if ( pollCb && pollCb() ) {
../ezca.c:5529:1: note: in expansion of macro 'EZCA_UNLOCK'
 5529 | EZCA_UNLOCK();
../ezca.c:5546:1: note: in expansion of macro 'EZCA_LOCK'
 5546 | EZCA_LOCK();
../ezca.c: In function 'EzcaPendIO':
../ezca.c:5584:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
 5584 |     if (Trace || Debug)
../ezca.c:5587:9: note: ...this statement, but the latter is misleadingly indented as if it were gua
rded by the 'if'
 5587 |         if ( pollCb && pollCb() ) {
../ezca.c:5590:1: note: in expansion of macro 'EZCA_UNLOCK'
 5590 | EZCA_UNLOCK();
../ezca.c:5595:1: note: in expansion of macro 'EZCA_LOCK'
 5595 | EZCA_LOCK();
../ezca.c: In function 'my_connection_callback':
../ezca.c:5697:1: note: in expansion of macro 'EZCA_LOCK'
 5697 | EZCA_LOCK();
../ezca.c:5716:1: note: in expansion of macro 'EZCA_UNLOCK'
 5716 | EZCA_UNLOCK();
../ezca.c: In function 'my_get_callback':
../ezca.c:5755:1: note: in expansion of macro 'EZCA_LOCK'
 5755 | EZCA_LOCK();
../ezca.c:6949:13: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
 6949 |             if (Trace || Debug)
../ezca.c:6951:17: note: ...this statement, but the latter is misleadingly indented as if it were gu
arded by the 'if'
 6951 |                 recycle_work(wp);
../ezca.c:6963:1: note: in expansion of macro 'EZCA_UNLOCK'
 6963 | EZCA_UNLOCK();
../ezca.c: In function 'my_monitor_callback':
../ezca.c:6999:1: note: in expansion of macro 'EZCA_LOCK'
 6999 | EZCA_LOCK();
../ezca.c:7191:1: note: in expansion of macro 'EZCA_UNLOCK'
 7191 | EZCA_UNLOCK();
../ezca.c: In function 'my_put_callback':
../ezca.c:7217:1: note: in expansion of macro 'EZCA_LOCK'
 7217 | EZCA_LOCK();
../ezca.c:7249:13: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
 7249 |             if (Trace || Debug)
../ezca.c:7251:17: note: ...this statement, but the latter is misleadingly indented as if it were gu
arded by the 'if'
 7251 |                 recycle_work(wp);
../ezca.c:7263:1: note: in expansion of macro 'EZCA_UNLOCK'
 7263 | EZCA_UNLOCK();
../ezca.c: In function 'print_discarded_channels':
../ezca.c:7886:5: warning: this 'for' clause does not guard... [-Wmisleading-indentation]
 7886 |     for (cp = Discarded_channels; cp; cp = cp->next)
../ezca.c:7888:9: note: ...this statement, but the latter is misleadingly indented as if it were gua
rded by the 'for'
 7888 |         printf("\n");
g++ -o ezcamt.dll -shared -Wl,--out-implib,libezcamt.dll.a -L/home/boj/epics-labca-labca_3_8_1/lib/windows-x64-mingw -L/home/boj/base-3.15.9/lib/windows-x64-mingw -m64              ezca.obj    -lca -lCom      -lws2_32 -ladvapi32 -luser32 -lkernel32 -lwinmm
Installing shared library ../../bin/windows-x64-mingw/ezcamt.dll
mkdir ../../bin
mkdir ../../bin/windows-x64-mingw
Installing DLL stub library ../../lib/windows-x64-mingw/libezcamt.dll.a
mkdir ../../lib
mkdir ../../lib/windows-x64-mingw
make[2]: Leaving directory '/home/boj/epics-labca-labca_3_8_1/ezca/O.windows-x64-mingw'
make[1]: Leaving directory '/home/boj/epics-labca-labca_3_8_1/ezca'
make -C ./glue install
make[1]: Entering directory '/home/boj/epics-labca-labca_3_8_1/glue'
make[2]: Entering directory '/home/boj/epics-labca-labca_3_8_1/glue/O.windows-x64-mingw' g++          -DMATLAB_APP    -D_MINGW -D__USE_MINGW_ANSI_STDIO -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/WIN32 -I../../include -I/home/boj/base-3.15.9/include/compiler/gcc -I/home/boj/base-3.15.9/include/os/WIN32 -I/home/boj/base-3.15.9/include             -I../../ezca -I/d/Matlab2022a/extern/include     -MM -MF ini.d -MT ini.obj ../ini.cc gcc          -DMATLAB_APP    -D_MINGW -D__USE_MINGW_ANSI_STDIO -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL    -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/WIN32 -I../../include -I/home/boj/base-3.15.9/include/compiler/gcc -I/home/boj/base-3.15.9/include/os/WIN32 -I/home/boj/base-3.15.9/include             -I../../ezca -I/d/Matlab2022a/extern/include     -MM -MF multiEzca.d -MT multiEzca.obj ../multiEzca.c gcc          -DMATLAB_APP    -D_MINGW -D__USE_MINGW_ANSI_STDIO -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL    -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/WIN32 -I../../include -I/home/boj/base-3.15.9/include/compiler/gcc -I/home/boj/base-3.15.9/include/os/WIN32 -I/home/boj/base-3.15.9/include             -I../../ezca -I/d/Matlab2022a/extern/include     -MM -MF ctrlC-polled.d -MT ctrlC-polled.obj ../ctrlC-polled.c
perl -CSD -MExtUtils::Command -e rm_f gitstring.c.new
perl > gitstring.c.new -e "print(\"const char *gitRevisionString = \\\"labca_3_8_1 - ef74a39\\\";\n\")" > gitstring.c.new perl -MFile::Compare -e 'exit( compare(@ARGV[0],@ARGV[1]) )' gitstring.c.new gitstring.c || (perl -CSD -MExtUtils::Command -e rm_f gitstring.c; perl -e 'rename("gitstring.c.new","gitstring.c")')
gcc          -DMATLAB_APP    -D_MINGW -D__USE_MINGW_ANSI_STDIO -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL    -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/WIN32 -I../../include -I/home/boj/base-3.15.9/include/compiler/gcc -I/home/boj/base-3.15.9/include/os/WIN32 -I/home/boj/base-3.15.9/include             -I../../ezca -I/d/Matlab2022a/extern/include     -MM -MF gitstring.d -MT gitstring.obj gitstring.c gcc          -DMATLAB_APP    -D_MINGW -D__USE_MINGW_ANSI_STDIO -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL    -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/WIN32 -I../../include -I/home/boj/base-3.15.9/include/compiler/gcc -I/home/boj/base-3.15.9/include/os/WIN32 -I/home/boj/base-3.15.9/include             -I../../ezca -I/d/Matlab2022a/extern/include     -MM -MF mglue.d -MT mglue.obj ../mglue.c g++          -DMATLAB_APP    -D_MINGW -D__USE_MINGW_ANSI_STDIO -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/WIN32 -I../../include -I/home/boj/base-3.15.9/include/compiler/gcc -I/home/boj/base-3.15.9/include/os/WIN32 -I/home/boj/base-3.15.9/include             -I../../ezca -I/d/Matlab2022a/extern/include    -o ini.obj -c ../ini.cc gcc          -DMATLAB_APP    -D_MINGW -D__USE_MINGW_ANSI_STDIO -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL    -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/WIN32 -I../../include -I/home/boj/base-3.15.9/include/compiler/gcc -I/home/boj/base-3.15.9/include/os/WIN32 -I/home/boj/base-3.15.9/include             -I../../ezca -I/d/Matlab2022a/extern/include    -o multiEzca.obj -c ../multiEzca.c
../multiEzca.c:27: warning: "isnan" redefined
   27 | #define isnan _isnan
In file included from ../multiEzca.c:13:
C:/msys64/mingw64/include/math.h:586: note: this is the location of the previous definition
  586 | #define isnan(x) \
In file included from ../multiEzca.c:32:
D:/Matlab2022a/extern/include/mex.h:197: warning: "printf" redefined
  197 | #define printf mexPrintf
In file included from ../multiEzca.c:24:
C:/msys64/home/boj/base-3.15.9/include/epicsStdio.h:41: note: this is the location of the previous d
efinition
   41 | #  define printf epicsStdoutPrintf
gcc          -DMATLAB_APP    -D_MINGW -D__USE_MINGW_ANSI_STDIO -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL    -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/WIN32 -I../../include -I/home/boj/base-3.15.9/include/compiler/gcc -I/home/boj/base-3.15.9/include/os/WIN32 -I/home/boj/base-3.15.9/include             -I../../ezca -I/d/Matlab2022a/extern/include    -o ctrlC-polled.obj -c ../ctrlC-polled.c gcc          -DMATLAB_APP    -D_MINGW -D__USE_MINGW_ANSI_STDIO -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL    -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/WIN32 -I../../include -I/home/boj/base-3.15.9/include/compiler/gcc -I/home/boj/base-3.15.9/include/os/WIN32 -I/home/boj/base-3.15.9/include             -I../../ezca -I/d/Matlab2022a/extern/include    -o gitstring.obj -c gitstring.c gcc          -DMATLAB_APP    -D_MINGW -D__USE_MINGW_ANSI_STDIO -O3   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL    -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/WIN32 -I../../include -I/home/boj/base-3.15.9/include/compiler/gcc -I/home/boj/base-3.15.9/include/os/WIN32 -I/home/boj/base-3.15.9/include             -I../../ezca -I/d/Matlab2022a/extern/include    -o mglue.obj -c ../mglue.c g++ -o mezcaglue.dll -shared -Wl,--out-implib,libmezcaglue.dll.a -L/home/boj/epics-labca-labca_3_8_1/lib/windows-x64-mingw -L/home/boj/base-3.15.9/lib/windows-x64-mingw /d/Matlab2022a/extern/lib/win64/mingw64/libut.lib /d/Matlab2022a/extern/lib/win64/mingw64/libmx.lib /d/Matlab2022a/extern/lib/win64/mingw64/libmex.lib -m64               ini.obj multiEzca.obj ctrlC-polled.obj gitstring.obj mglue.obj   -lezcamt -lca -lCom  -luser32 -lws2_32 -ladvapi32 -luser32 -lkernel32 -lwinmm
: ini.obj:ini.cc:(.text+0x126): undefined reference to `mxGetScalar_800'
: ini.obj:ini.cc:(.text+0x1d9): undefined reference to `mexCallMATLAB_800'
: ini.obj:ini.cc:(.text+0x256): undefined reference to `mxGetScalar_800'
: ini.obj:ini.cc:(.text+0x37e): undefined reference to `mexCallMATLAB_800'
: ini.obj:ini.cc:(.text+0x39e): undefined reference to `mxGetScalar_800'
: ini.obj:ini.cc:(.text+0x4e6): undefined reference to `mexCallMATLAB_800'
: ini.obj:ini.cc:(.text+0x506): undefined reference to `mxGetScalar_800'
: ini.obj:ini.cc:(.text+0x5d0): undefined reference to `mexCallMATLABWithTrap_800'
: ini.obj:ini.cc:(.text+0x5f7): undefined reference to `mxDestroyArray_800'
: ini.obj:ini.cc:(.text+0x678): undefined reference to `mexLock_800'
: ini.obj:ini.cc:(.text+0x6b1): undefined reference to `mexCallMATLAB_800'
: ini.obj:ini.cc:(.text+0x726): undefined reference to `mxIsChar_800'
: ini.obj:ini.cc:(.text+0x74e): undefined reference to `mxGetScalar_800'
: ini.obj:ini.cc:(.text+0x796): undefined reference to `mxGetN_800'
: ini.obj:ini.cc:(.text+0x7b9): undefined reference to `mxGetString_800'
: ini.obj:ini.cc:(.text+0x997): undefined reference to `mexCallMATLABWithTrap_800'
: ini.obj:ini.cc:(.text+0x9c2): undefined reference to `mxDestroyArray_800'
: ini.obj:ini.cc:(.text+0xa48): undefined reference to `mexLock_800'
: ini.obj:ini.cc:(.text+0xa81): undefined reference to `mexCallMATLAB_800'
: ini.obj:ini.cc:(.text+0xb06): undefined reference to `mxIsChar_800'
: ini.obj:ini.cc:(.text+0xb36): undefined reference to `mxGetScalar_800'
: ini.obj:ini.cc:(.text+0xb86): undefined reference to `mxGetN_800'
: ini.obj:ini.cc:(.text+0xba9): undefined reference to `mxGetString_800'
: multiEzca.obj:multiEzca.c:(.text+0x11d): undefined reference to `mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x145): undefined reference to `mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x3dd): undefined reference to `mexPrintf_800'
: multiEzca.obj:multiEzca.c:(.text+0x5c3): undefined reference to `mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x5db): undefined reference to `mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x6ea): undefined reference to `mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x914): undefined reference to `mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x91e): undefined reference to `mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x928): undefined reference to `mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0xe84): undefined reference to `mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x1062): undefined reference to `mxCalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x107a): undefined reference to `mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x1238): undefined reference to `mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x1242): undefined reference to `mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x124c): undefined reference to `mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x1256): undefined reference to `mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x1260): undefined reference to `mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x126a): more undefined references to `mxFree_800' follow
: multiEzca.obj:multiEzca.c:(.text+0x1326): undefined reference to `mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x1346): undefined reference to `mxCalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x136c): undefined reference to `mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x138e): undefined reference to `mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x1847): undefined reference to `mexPrintf_800'
: multiEzca.obj:multiEzca.c:(.text+0x187f): undefined reference to `mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x1e19): undefined reference to `mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x1f51): undefined reference to `mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x1fe7): undefined reference to `mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x2063): undefined reference to `mxCalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x322e): undefined reference to `mxCalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x335b): undefined reference to `mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x35e4): undefined reference to `mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x365a): undefined reference to `mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x3662): undefined reference to `mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x39d7): undefined reference to `mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x3ad4): undefined reference to `mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x3b42): undefined reference to `mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x3b68): more undefined references to `mxFree_800' follow
: ctrlC-polled.obj:ctrlC-polled.c:(.text+0x5): undefined reference to `utHandlePendingInterrupt'
: mglue.obj:mglue.c:(.text+0x29): undefined reference to `mxFree_800'
: mglue.obj:mglue.c:(.text+0x38): undefined reference to `mxFree_800'
: mglue.obj:mglue.c:(.text+0x9c): undefined reference to `mxIsCell_800'
: mglue.obj:mglue.c:(.text+0xac): undefined reference to `mxIsCell_800'
: mglue.obj:mglue.c:(.text+0xbc): undefined reference to `mxIsCell_800'
: mglue.obj:mglue.c:(.text+0xd3): undefined reference to `mxCalloc_800'
: mglue.obj:mglue.c:(.text+0xf4): undefined reference to `mxIsChar_800'
: mglue.obj:mglue.c:(.text+0x100): undefined reference to `mxGetM_800'
: mglue.obj:mglue.c:(.text+0x10e): undefined reference to `mxGetN_800'
: mglue.obj:mglue.c:(.text+0x11b): undefined reference to `mxMalloc_800'
: mglue.obj:mglue.c:(.text+0x136): undefined reference to `mxGetString_800'
: mglue.obj:mglue.c:(.text+0x156): undefined reference to `mxIsCell_800'
: mglue.obj:mglue.c:(.text+0x165): undefined reference to `mxGetCell_800'
: mglue.obj:mglue.c:(.text+0x1a9): undefined reference to `mxFree_800'
: mglue.obj:mglue.c:(.text+0x1b8): undefined reference to `mxFree_800'
: mglue.obj:mglue.c:(.text+0x1e4): undefined reference to `mxGetN_800'
: mglue.obj:mglue.c:(.text+0x214): undefined reference to `mxIsChar_800'
: mglue.obj:mglue.c:(.text+0x241): undefined reference to `mxGetM_800'
: mglue.obj:mglue.c:(.text+0x24c): undefined reference to `mxIsCell_800'
: mglue.obj:mglue.c:(.text+0x266): undefined reference to `mxCalloc_800'
: mglue.obj:mglue.c:(.text+0x2e4): undefined reference to `mxIsChar_800'
: mglue.obj:mglue.c:(.text+0x404): undefined reference to `mxIsChar_800'
: mglue.obj:mglue.c:(.text+0x41b): undefined reference to `mxGetString_800'
: mglue.obj:mglue.c:(.text+0x510): undefined reference to `mxDestroyArray_800'
: mglue.obj:mglue.c:(.text+0x581): undefined reference to `mxGetN_800'
: mglue.obj:mglue.c:(.text+0x58e): undefined reference to `mxGetM_800'
: mglue.obj:mglue.c:(.text+0x59b): undefined reference to `mxIsChar_800'
: mglue.obj:mglue.c:(.text+0x5ae): undefined reference to `mxIsCell_800'
: mglue.obj:mglue.c:(.text+0x5d5): undefined reference to `mxCalloc_800'
: mglue.obj:mglue.c:(.text+0x5fc): undefined reference to `mxGetM_800'
: mglue.obj:mglue.c:(.text+0x60a): undefined reference to `mxGetN_800'
: mglue.obj:mglue.c:(.text+0x617): undefined reference to `mxMalloc_800'
: mglue.obj:mglue.c:(.text+0x632): undefined reference to `mxGetString_800'
: mglue.obj:mglue.c:(.text+0x652): undefined reference to `mxGetCell_800'
: mglue.obj:mglue.c:(.text+0x65d): undefined reference to `mxIsChar_800'
: mglue.obj:mglue.c:(.text+0x699): undefined reference to `mxFree_800'
: mglue.obj:mglue.c:(.text+0x6a6): undefined reference to `mxFree_800'
: mglue.obj:mglue.c:(.text+0x6b3): undefined reference to `mxDestroyArray_800'
: mglue.obj:mglue.c:(.text+0x6d9): undefined reference to `mxFree_800'
: mglue.obj:mglue.c:(.text+0x6ea): undefined reference to `mxFree_800'
: mglue.obj:mglue.c:(.text+0x71b): undefined reference to `mxCreateCellMatrix_800'
: mglue.obj:mglue.c:(.text+0x732): undefined reference to `mxDuplicateArray_800'
: mglue.obj:mglue.c:(.text+0x73f): undefined reference to `mxSetCell_800'
: mglue.obj:mglue.c:(.text+0x759): undefined reference to `mxIsCell_800'
: mglue.obj:mglue.c:(.text+0x76d): undefined reference to `mxIsDouble_800'
: mglue.obj:mglue.c:(.text+0x8b5): undefined reference to `mxGetPr_800'
On 18-12-2023 18:49, Freddie Akeroyd - STFC UKRI wrote:
Hi Bo,
Do you see the same error as Giovanni saw, or are you getting a different build failure?
Freddie
RE: LabCA for MATLAB Installation error Freddie Akeroyd - STFC UKRI via Tech-talk
LabCA for MATLAB Installation error Giovanni Franzini via Tech-talk
Re: LabCA for MATLAB Installation error Straumann Till Sascha via Tech-talk
Re: LabCA for MATLAB Installation error boj via Tech-talk
Prev: Steps for installing any EPICS Device Support module Eusebio Naif Al-Soliman Fuentes via Tech-talk
Next: Agilent analytics devices like GCs (gas chromatography) integration into EPICS framework? Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: RE: LabCA for MATLAB Installation error Freddie Akeroyd - STFC UKRI via Tech-talk
Next: RE: LabCA for MATLAB Installation error Freddie Akeroyd - STFC UKRI via Tech-talk
