1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: quadEM-R7-0 ParamValNotDefined
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Wed, 20 Dec 2023 10:34:54 +0100
On Wed, 20 Dec 2023 at 01:23, Mark Rivers via Tech-talk <[email protected]> wrote:
Note that it is calling paramVal::getInteger in a try/catch block that explicitly catches the exception you are getting, ParamValNotDefined.  So I don't understand why this is causing your program to terminate, rather than simply catching the error and return and error status.
It seems like perhaps there is something different about the way C++ exception handling works with the linux-arm architecture?  No one has ever reported this error before, but most people are using linux-x86_64.
Just poking...
Inside the ARM toolchain doc [1] I found that
The ARM compilation tools fully support C++ exception handling. However, the compiler does not support this by default. You must enable C++ exception handling with the --exceptions option.
Far too obvious to be the cause, is it?
Cheers,
~Ralph
Re: quadEM-R7-0 ParamValNotDefined Érico Nogueira Rolim via Tech-talk
quadEM-R7-0 ParamValNotDefined Rong Huang via Tech-talk
RE: quadEM-R7-0 ParamValNotDefined Mark Rivers via Tech-talk
Re: quadEM-R7-0 ParamValNotDefined Rong Huang via Tech-talk
Prev: Re: Steps for installing any EPICS Device Support module Ralph Lange via Tech-talk
Next: Re: quadEM-R7-0 ParamValNotDefined Érico Nogueira Rolim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: quadEM-R7-0 ParamValNotDefined Rong Huang via Tech-talk
