1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Steps for installing any EPICS Device Support module
From: Eusebio Naif Al-Soliman Fuentes via Tech-talk <[email protected]>
To: Ralph Lange <[email protected]>
Cc: Tech Talk <[email protected]>
Date: Wed, 20 Dec 2023 14:44:23 +0100
Hello Ralph.
Sorry, I don't see the binary distribution in the 'Assets' folder of the releases in GitHub (https://github.com/epics-modules/opcua/releases), all the releases need to be compiled, apparently.
If I define the EPICS_BASE = /path/to/my/EPICS/Base/install inside the configure/RELEASE file of the EPICS Module, and I compile with 'make', I obtain a binary file inside bin/linux-x86_64/
However, I have found that the binaries that I obtain with the compilation of RecCaster and the OPC UA Module work only with Channel Access and not pvAccess. That's why I'm trying to "compile" or "use" in some way the "softIocPVA" binary. What should I have to do to in order to use pvAccess in that case?
Also, I still don't know how to run at the same time two or more modules, for example, the RecCaster and the OPC UA module with the same PV like 'temperature:water'. In summary, what I want to do is to use at the same time the ChannelFinder service and the OPC UA Device Support for the same PVs (from an IOC db). Additionally better if we can use PVA.
Sorry for being so annoying, I'm having big issues understanding how the EPICS Support Modules are used.
Thanks Eusebio.
Saludos/Best regards
University of Granada
MSc. Data Science and Computer Engineering
[email protected]
El 2023-12-20 10:12, Ralph Lange escribió:
Hi Eusebio,
On Wed, 20 Dec 2023 at 08:53, Eusebio Naif Al-Soliman Fuentes <
[email protected]> wrote:
In that case, I understand that I have to use the binaries of the EPICS
Support Module instead of the ones from EPICS Base.
I'm not sure I understand what you mean.
If you are referring to the OPC UA Device Support, you can use the binary
distribution if you don't want to or can't compile the low-level client
library. When you use the binary distribution, you don't need to
download/compile the Device Support module nor the low-level client
library, as both are part of the binary distribution.
However, what happens if I want to use, with the same PVs, EPICS Base and
the EPICS Support Module? Or, for instance, two different EPICS Modules
with the same PVs?
That question does not really make sense.
EPICS Base contains some libraries and configuration files. Additional
EPICS support modules contain more libraries and configuration files.
To create an IOC that uses things from support modules, you need both EPICS
Base and the support modules. The IOC binary needs to be linked against the
libraries from the support modules and EPICS Base. Configuration files from
the support modules and EPICS Base are used to create the configuration
files for the IOC.
EPICS relies on PV names to be unique in the system. Running multiple IOCs
with the same PVs is an error. Clients will connect to one or another
quasi-randomly and spit out error messages.
I've to use a RELEASE.local file, but what do I have to write on it and in
which location should reside in order to use EPICS Base and the modules
together?
Any EPICS build (when you run "make" inside an EPICS module) will look for
RELEASE.local files in different places, including in the directory above
its TOP and inside the TOP/configure directory.
If you don't want to repeat the configuration inside every support module,
putting a single file one level above the modules is read by all of them.
RELEASE and RELEASE.local files contain (that's documented) the locations
of all support modules as multiple lines of the form
    MODULE_NAME = /absolute/path/to/the/module
with the EPICS_BASE definition usually last.
Cheers,
~Ralph
Re: Steps for installing any EPICS Device Support module Érico Nogueira Rolim via Tech-talk
Steps for installing any EPICS Device Support module Eusebio Naif Al-Soliman Fuentes via Tech-talk
Re: Steps for installing any EPICS Device Support module Ralph Lange via Tech-talk
Re: Steps for installing any EPICS Device Support module Eusebio Naif Al-Soliman Fuentes via Tech-talk
Prev: Re: quadEM-R7-0 ParamValNotDefined Érico Nogueira Rolim via Tech-talk
Next: Re: Steps for installing any EPICS Device Support module Érico Nogueira Rolim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Steps for installing any EPICS Device Support module Ralph Lange via Tech-talk
