Hi Sky,
after a long struggle I found out that the war files where build correctly, but not properly deployed by the deployMultipleTomcats.py script.
This creates only the directories and copies the default apps from the tomcat distribution folder. Once tomcat gets started the war files
are not automatically deployed, at least by tomcat 9.0.85! The full installation is only done by the singe_machine_install.sh script. This creates the deployRelease.sh script which does the necessary unpacking on the war files into the sub directories.
In this point the documentation for developers could be improved. It shows in the Deploy section how to copy the war files, but the unpacking step is missing.
It should be mentioned that one should first have a full setup done with single_machine_install.sh before installing from a development directory.
As the single_machiene_install.sh script is interactive using zenity, I can not use it in my ansible based setup.
Now everything is working (based on the 1.0.1 branch).
Thanks
Joern
Am Mittwoch, 14. Februar 2024, 09:52:18 CET schrieb Sky Brewer via Tech-talk:
> Hi Jörn,
> Can you be more specific about the problem? When you start up the archiver do you see any messages in the logs (Catalina.out files or what you specify in the log4j2.xml file default being logs/arch.log and Syslog).
> After building the project with ./gradlew the distribution of the project should be found in “build/distributions”. The ui for the mgmt. service is then in the mgmt.war inside the archappl-{version}.tar.gz inside the ui folder.
> You should have something like:
> ls ui/
> appliance.html css integration.html pvdetails.html storage.html
> cacompare.html help js redirect.html
> comm index.html metrics.html reports.html
> Let me know if you have any other questions or what documentation should be updated to make this clearer.
> Thanks
> Sky
- Re: Failed to build archiver appliance Sky Brewer via Tech-talk
ADPICam: epicsMutexOsdUnlock failed: ERROR Operation not permitted Fernando Ardana via Tech-talk
<2024>
2025
2026
Epics motor driver dval init Paul-Elie GUILLOT via Tech-talk
<2024>
2025
2026
