1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: pvAccess assert error
Date: Tue, 27 Feb 2024 00:37:20 +0000
Folks, I am running a new areaDetector camera. It generates frames that are 4096x3072 pixels, 8-bit. I can collect data from the camera at 150 frames/s using a BitFlow CoaXSpress card with no problems. This is on a Windows PC. However, when
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
Folks,
However, when I try to use pvAccess to read the data from the NDPluginPva plugin I get an assert error in pvAccess in my Windows application.  The error message is in the attachment.
This happens when I use the ImageJ pvAccess plugin, and also when I use the following Linux command on another machine:
$ pvmonitor 13BF1:Pva1:Image > /dev/null
Any idea what the problem could be?  This is base 7.0.7.
Attachment: pvAccessAssertError.png
Description: pvAccessAssertError.png
RE: pvAccess assert error Mark Rivers via Tech-talk
Re: pvAccess assert error Michael Davidsaver via Tech-talk
Prev: Re: Commands with synchronous answers from python Kasemir, Kay via Tech-talk
Next: RE: pvAccess assert error Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: devAsynFloat64::processCallbackInput process read error Mark Rivers via Tech-talk
