1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: pvAccess assert error
From: Michael Davidsaver via Tech-talk <[email protected]>
Date: Wed, 28 Feb 2024 10:20:12 -0800
On 2/26/24 16: 37, Mark Rivers via Tech-talk wrote: > Folks, > > I am running a new areaDetector camera.   It generates frames that are 4096x3072 pixels, 8-bit.   I can collect data from the camera at 150 frames/s using a BitFlow CoaXSpress
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
On 2/26/24 16:37, Mark Rivers via Tech-talk wrote:
> Folks,
> I am running a new areaDetector camera.  It generates frames that are 4096x3072 pixels, 8-bit.  I can collect data from the camera at 150 frames/s using a BitFlow CoaXSpress card with no problems.  This is on a Windows PC.
> However, when I try to use pvAccess to read the data from the NDPluginPva plugin I get an assert error in pvAccess in my Windows application.  The error message is in the attachment.
> This happens when I use the ImageJ pvAccess plugin, and also when I use the following Linux command on another machine:
> $ pvmonitor 13BF1:Pva1:Image > /dev/null
> Any idea what the problem could be?  This is base 7.0.7.
At a guess, maybe another size()==0 situations as with:
https://urldefense.us/v3/__https://github.com/epics-base/pvDataCPP/issues/50__;!!G_uCfscf7eWS!dKzxPO7_6scRF7SD97tOLelkaI-1U-5UWXzWHc_eslUrlpyQX4qpOsHm53zsGvqwBqR5fNAOqlqPw4BxGew4HGIU3A$
If so, a full stack trace should point at the offending code.
RE: pvAccess assert error Mark Rivers via Tech-talk
Prev: Reg : How to use custom baud rate such as 125000 for ioc running on Linux Abhishek Mazumdar - STFC UKRI via Tech-talk
Next: RE: pvAccess assert error Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: RE: pvAccess assert error Mark Rivers via Tech-talk
