1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: RE: pvAccess assert error
To: 'Michael Davidsaver' <[email protected]>
Date: Wed, 28 Feb 2024 18:49:49 +0000
Hi Michael, I sent a message to both tech-talk and core-talk at 4: 31 PM CST yesterday. This is the tech-talk message: https: //urldefense. us/v3/__https: //epics. anl. gov/tech-talk/2024/msg00292. php__;!!G_uCfscf7eWS!bmNOpw5FmWhW7J7hs8k7hKunvAJL1KAiUVMtLWg60M_Y0F1qm_3OzyqHEmb4XBjxPF1v6SfNStId44T8heqsxHQCaqI$
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
Hi Michael,
I sent a message to both tech-talk and core-talk at 4:31 PM CST yesterday.
https://urldefense.us/v3/__https://epics.anl.gov/tech-talk/2024/msg00292.php__;!!G_uCfscf7eWS!bmNOpw5FmWhW7J7hs8k7hKunvAJL1KAiUVMtLWg60M_Y0F1qm_3OzyqHEmb4XBjxPF1v6SfNStId44T8heqsxHQCaqI$
This is the core-talk message:
https://urldefense.us/v3/__https://epics.anl.gov/core-talk/2024/msg00042.php__;!!G_uCfscf7eWS!bmNOpw5FmWhW7J7hs8k7hKunvAJL1KAiUVMtLWg60M_Y0F1qm_3OzyqHEmb4XBjxPF1v6SfNStId44T8heqss-cSrlI$
However, I did not actually then receive the message from tech-talk.  And it seems like maybe you did not either?  It seems like tech-talk archived it but did not send it?
-----Original Message-----
Sent: Wednesday, February 28, 2024 12:31 PM
Subject: Re: pvAccess assert error
Hi Mark,
Am I being dense today?  I only see a screen capture attached to your original mail.
On 2/28/24 10:25, Mark Rivers wrote:
> Hi Michael,
> Thanks for the reply.  I sent the full stack trace yesterday.
> Mark
> From: Michael Davidsaver <[email protected]>
> Sent: Wednesday, February 28, 2024 12:20 PM
> Cc: [email protected]
> On 2/26/24 16:37, Mark Rivers via Tech-talk wrote:
>> Folks,
>> I am running a new areaDetector camera.  It generates frames that are 4096x3072 pixels, 8-bit.  I can collect data from the camera at 150 frames/s using a BitFlow CoaXSpress card with no problems.  This is on a Windows PC.
>> However, when I try to use pvAccess to read the data from the NDPluginPva plugin I get an assert error in pvAccess in my Windows application.  The error message is in the attachment.
>> This happens when I use the ImageJ pvAccess plugin, and also when I use the following Linux command on another machine:
>> $ pvmonitor 13BF1:Pva1:Image > /dev/null
>> Any idea what the problem could be?  This is base 7.0.7.
> At a guess, maybe another size()==0 situations as with:
> https://urldefense.us/v3/__https://github.com/epics-base/pvDataCPP/issues/50__;!!G_uCfscf7eWS!bmNOpw5FmWhW7J7hs8k7hKunvAJL1KAiUVMtLWg60M_Y0F1qm_3OzyqHEmb4XBjxPF1v6SfNStId44T8heqskRlwRS8$
> If so, a full stack trace should point at the offending code.
Re: pvAccess assert error Michael Davidsaver via Tech-talk
pvAccess assert error Mark Rivers via Tech-talk
RE: pvAccess assert error Mark Rivers via Tech-talk
Prev: RE: pvAccess assert error Mark Rivers via Tech-talk
Next: Re: pvAccess assert error Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
