1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: archiver appliance quickstart installation
From: "Wang, Lin via Tech-talk" <[email protected]>
To: "Rong Huang" <[email protected]>
Cc: [email protected]
Date: Fri, 1 Mar 2024 09:12:50 +0800 (GMT+08:00)
Hello Rong, The Data Browser tool in CSS and Phoebus can be used to retrieve data from Archiver Appliance. Archiver Appliance also comes with a data retrieval page as follows, which can be navigated from the "Quick chart" button in PV status
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
Hello Rong,
Archiver Appliance also comes with a data retrieval page as follows, which can be navigated from the "Quick chart" button in PV status or PV report table.
http://localhost:17668/retrieval/ui/viewer/archViewer.html
Lin
-----Original Messages-----
Send time: Friday, 03/01/2024 06:43:56
To: "Wang, Lin" <[email protected]>
Hello Lin,
That works! One step forward! Thanks a lot!
After archiving a few test PVs, now I have questions about retrieving.
I copied pbrawclient-0.0.8.jar to quickstart_tomcat/apache-tomcat-9.0.86/lib/ and /usr/lib/jvm/java-17-openjdk-amd64/lib/.
But on firefox, after entering phraw://localhost:17665/retrieval, it went to google search page looking for "phraw://localhost:17665/retrieval".
Trying Safari, it just says: Safai cannot open the page because the address is invalid.
Does that mean I have to install CSS?
Maybe I just need to spend more time trying this: on appliance main page, the tab of "Archive (specify sampling period)", even I entered 5 second, the status page still says 1 second period.
Rong
On Thu, Feb 29, 2024 at 3:01 AM Wang, Lin <[email protected]> wrote:
Hello Rong,
According to the thread below, it seems that Archiver Appliance currently is not compatible with Tomcat 10,
https://epics.anl.gov/tech-talk/2023/msg01830.php
You may want to try Tomcat 9 instead.
Lin
-----原始邮件-----
发件人: "Rong Huang via Tech-talk" <[email protected]>
发送时间: 2024-02-29 05:28:56 (星期四)
收件人: [email protected]
主题: archiver appliance quickstart installation
Hello, Hope someone can help me on EPICS archiver appliance quickstart. I list what I did in the following, and please point out what I am missing or did wrong.   - computer system:  ubuntu 22. 04   - archiver appliance quickstart version:  archappl_v1. 1. 0
Hello,
  - computer system:  ubuntu 22.04
  - archiver appliance quickstart version:  archappl_v1.1.0
  1) epics base:   R7.0.8;  export EPICS_BASE=/home/archiver/epics/base
  2) openjdk-17-jdk; export JAVA_HOME=/usr/lib/jvm/java-17-openjdk-amd64
  3) download apache-tomcat-10.1.19. But later on disabled it by renaming the file /etc/systemd/system/tomcat.service to tomcat.service_NotUse, to avoid potential conflict with the tomcat loaded by quickstart.sh.
  4) installed mysql-server; also downloaded mysql-connector-java-8.3.0.jar, but is probably irrelevant since I can only copy this jar file into system tomcat which is disabled.
  5) download archappl_v1.1.0.tar.gz, apache-tomcat-10.1.19.tar.gz into one directory, unzip archappl_v1.1.0; run `./quickstart.sh apache-tomcat-10.1.19.tar.gz`
  The only website I can see is localhost:17665, the apache Tomcat/10.1.19 webpage. "HTTP 404" for localhost:17665/mgmt/ui/index.html, or any other pages.
Beginning part of the screen printout and a log file are also included in this email.
Thanks a lot,
Rong
archiver appliance quickstart installation Rong Huang via Tech-talk
Re: archiver appliance quickstart installation Wang, Lin via Tech-talk
Re: archiver appliance quickstart installation Rong Huang via Tech-talk
Prev: Re: pvAccess assert error Johnson, Andrew N. via Tech-talk
Next: Re: Generating metrics for IOC applications Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: archiver appliance quickstart installation Rong Huang via Tech-talk
Next: communication issue Tran, Phi Dung via Tech-talk
