1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Possibility of adding/appending data to existing PVs
Date: Mon, 11 Mar 2024 16:10:06 +0000
To my knowledge the answer is mostly no. Exceptions are:
Data from another archiver can be merged in via the failover functionality:
https://slacmshankar.github.io/epicsarchiver_docs/api/org/epics/archiverappliance/mgmt/bpl/MergeInDataFromExternalStore.html
You can manually merge files using
edu.stanford.slac.archiverappliance.plain.utils. MergePBFile
From the github repo.
And you can merge two pvs using:
https://slacmshankar.github.io/epicsarchiver_docs/api/org/epics/archiverappliance/mgmt/bpl/AppendAndAliasPV.html
But there is not web api for sending existing data to a pv.
Sky
Prev: Possibility of adding/appending data to existing PVs Windsor Tanner via Tech-talk
Next: startPVAServer prevents windows-x64 IOC from exiting Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
