1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: startPVAServer prevents windows-x64 IOC from exiting
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 12 Mar 2024 20:54:19 +0000
Folks,
I have found a serious problem with using the PVA server on Windows IOCs that are dynamically built.  The IOC runs fine, but cannot be exited either with the “exit” command or with ^C.  It can only be killed with the Windows Task Manager.  The problem occurs on the following:
  • EPICS_HOST_ARCH: window-x64, windows-x64-debug.  Does not occur on windows-x64-static.
  • EPICS BASE: 7.0.7 and 7.0.8.  Did not test other versions.
  • Test application: makeBaseApp.pl from base 7.0.8.  Modified st.cmd to add the line startPVAServer just before iocInit.  Also happens in ADSimDetector with commonPlugins.cmd.
Prev: Re: Possibility of adding/appending data to existing PVs Sky Brewer via Tech-talk
Next: Galil controller with incremental encoder question Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
