1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re:Re: epics snmp
To: "Priller, John" <[email protected]>
Date: Thu, 14 Mar 2024 16:48:06 +0800 (CST)
Thank you for your  helpI changed the port to 5064. Now I have a new problem.
The value I get with the snmpget command is 219:
snmpget -v1 -c public 192.168.0.1 ENLOGIC-PDU-MIB::pduInputPhaseSTATUSEntry.6.1.1
ENLOGIC-PDU-MIB::pduInputPhaseSTATUSVoltage.1.1 = INTEGER: 219
The value obtained with caget is 0, which does not match the actual value:
caget  TEST:Voltage
TEST:Voltage      0
The db file is as follows:
record(ai,"$(DEV):Voltage")
    field(DESC,"SNMP channel")
    field(DTYP,"Snmp")
    field(SCAN,".2 second")
    field(PREC,"3")
    field(INP,"@$(HOST) public $(MIB)::pduInputPhaseSTATUSVoltage.1.1 Float 100")
The mib file is as follows:
pduInputPhaseSTATUSVoltage OBJECT-TYPE
  -- FROM       ENLOGIC-PDU-MIB
  SYNTAX        Integer32
  MAX-ACCESS    read-only
  STATUS        current
  DESCRIPTION   "Returns the voltage, in Volts(V)"
::= { pduInputPhaseSTATUSEntry 6 }
Is there an error somewhere in the db file?
White
At 2024-03-13 18:30:54, "Priller, John via Tech-talk" <[email protected]> wrote:
It doesn't appear to be related to SNMP (that's my driver, if you need help with it), it looks like the issue is you're changing the EPICS_CA_SERVER_PORT in your st.cmd.
By default, caget is going to use port 5064.  Do you also set an environment variable for this in the console you're running caget in?
To make doubly sure that your IOC does in fact have a TEST:Current record, what are the results of a "dbl" command in your IOC's shell?  You can add the dbl command to the end of your st.cmd to check the output from that, if you're not running the IOC with an active shell under procServ or similar.
From: Tech-talk <[email protected]> on behalf of White via Tech-talk <[email protected]>
Sent: Wednesday, March 13, 2024 4:44 AM
To: [email protected]
Subject: epics snmp
[EXTERNAL] This email originated from outside of FRIB
I'm trying to control the device using the SNMP protocol and the db file is as follows:
record(ai,"$(DEV):Current")
    field(DTYP,"Snmp")
    field(PREC,"3")
    field(INP,"@$(HOST) public $(MIB)::pduInputPhaseSTATUSCurrent.1.1 Float 100")
The st.cmd file are as follows:
< envPaths
epicsEnvSet("EPICS_CA_SERVER_PORT", 6310)
epicsEnvSet("EPICS_PVA_SERVER_PORT", 6710)
epicsEnvSet("MIBDIRS", "+$(TOP)/mibs:/usr/local/share/snmp/mibs")
epicsEnvSet("IOCNAME","npdu")
cd "${TOP}"
dbLoadDatabase "dbd/npdu.dbd"
npdu_registerRecordDeviceDriver pdbbase
devSnmpSetSnmpVersion(192.168.0.1:161,SNMP_VERSION_1)
devSnmpSetMaxOidsPerReq(192.168.0.1:161,50)
dbLoadRecords "db/dbpdux.db", "DEV=TEST, HOST=192.168.0.1, MIB=ENLOGIC-PDU-MIB"
cd "${TOP}/iocBoot/${IOC}"
iocInit
But there is an error:
 caget TEST:Current
Channel connect timed out: 'TEST:Current' not found.
If there is no error in the DB, the device is not connected, is there an error in the st.cmd file?
White
Re: epics snmp Jörn Dreyer via Tech-talk
epics snmp White via Tech-talk
Re: epics snmp Priller, John via Tech-talk
Prev: Re: Galil controller with incremental encoder question Mark Clift via Tech-talk
Next: Re: epics snmp Jörn Dreyer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: Re: epics snmp Priller, John via Tech-talk
