Hi White,
do you have access to the IOC shell?
If so, try the following:
dbpr TEST:Voltage
(This will print out the actual value (VAL field) as stored in the IOC database. Should be 0 as in the caget command)
dbtr TEST:Voltage
(This will trigger the processing of the record and print the result (VAL field))
Check the STAT field of both outputs. This will tell you if an error occurred during processing of the record.
Regards
Jörn
Am Donnerstag, 14. März 2024, 09:48:06 CET schrieb White via Tech-talk:
> Thank you for your help,I changed the port to 5064. Now I have a new problem.
> The value I get with the snmpget command is 219:
> snmpget -v1 -c public 192.168.0.1 ENLOGIC-PDU-MIB::pduInputPhaseSTATUSEntry.6.1.1
> ENLOGIC-PDU-MIB::pduInputPhaseSTATUSVoltage.1.1 = INTEGER: 219
> The value obtained with caget is 0, which does not match the actual value:
> caget TEST:Voltage
> TEST:Voltage 0
> The db file is as follows:
> record(ai,"$(DEV):Voltage")
> field(DESC,"SNMP channel")
> field(DTYP,"Snmp")
> field(SCAN,".2 second")
> field(PREC,"3")
> field(INP,"@$(HOST) public $(MIB)::pduInputPhaseSTATUSVoltage.1.1 Float 100")
> The mib file is as follows:
> pduInputPhaseSTATUSVoltage OBJECT-TYPE
> -- FROM ENLOGIC-PDU-MIB
> SYNTAX Integer32
> MAX-ACCESS read-only
> STATUS current
> DESCRIPTION "Returns the voltage, in Volts(V)"
> ::= { pduInputPhaseSTATUSEntry 6 }
> Is there an error somewhere in the db file?
> Thanks,
> White
> At 2024-03-13 18:30:54, "Priller, John via Tech-talk" <[email protected]> wrote:
> It doesn't appear to be related to SNMP (that's my driver, if you need help with it), it looks like the issue is you're changing the EPICS_CA_SERVER_PORT in your st.cmd.
> By default, caget is going to use port 5064. Do you also set an environment variable for this in the console you're running caget in?
> To make doubly sure that your IOC does in fact have a TEST:Current record, what are the results of a "dbl" command in your IOC's shell? You can add the dbl command to the end of your st.cmd to check the output from that, if you're not running the IOC with an active shell under procServ or similar.
> From: Tech-talk <[email protected]> on behalf of White via Tech-talk <[email protected]>
> Sent: Wednesday, March 13, 2024 4:44 AM
> To: [email protected]
> Subject: epics snmp
> [EXTERNAL] This email originated from outside of FRIB
> Hi,
> I'm trying to control the device using the SNMP protocol and the db file is as follows:
> record(ai,"$(DEV):Current")
> field(DTYP,"Snmp")
> field(PREC,"3")
> field(INP,"@$(HOST) public $(MIB)::pduInputPhaseSTATUSCurrent.1.1 Float 100")
> The st.cmd file are as follows:
> < envPaths
> epicsEnvSet("EPICS_CA_SERVER_PORT", 6310)
> epicsEnvSet("EPICS_PVA_SERVER_PORT", 6710)
> epicsEnvSet("MIBDIRS", "+$(TOP)/mibs:/usr/local/share/snmp/mibs")
> epicsEnvSet("IOCNAME","npdu")
> cd "${TOP}"
> ## Register all support components
> dbLoadDatabase "dbd/npdu.dbd"
> npdu_registerRecordDeviceDriver pdbbase
> devSnmpSetSnmpVersion(192.168.0.1:161,SNMP_VERSION_1)
> devSnmpSetMaxOidsPerReq(192.168.0.1:161,50)
> dbLoadRecords "db/dbpdux.db", "DEV=TEST, HOST=192.168.0.1, MIB=ENLOGIC-PDU-MIB"
> cd "${TOP}/iocBoot/${IOC}"
> iocInit
> But there is an error:
> caget TEST:Current
> Channel connect timed out: 'TEST:Current' not found.
> If there is no error in the DB, the device is not connected, is there an error in the st.cmd file?
> Thanks,
> White
- Re: epics snmp Priller, John via Tech-talk
- epics snmp White via Tech-talk
- Re:Re: epics snmp White via Tech-talk
<2024>
2025
2026
<2024>
2025
2026
