1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: Control device via epics-snmp
From: "Priller, John via Tech-talk" <[email protected]>
To: White <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 20 Mar 2024 14:36:40 +0000
You seem to be missing the last item on the OUT line, which is the SNMP format character to use when writing the value to the device.  That would be an 'i' for an integer or an 'F' for a float (yes, they use different case, no idea why).
So:
field(OUT,"@$(HOST) private $(MIB)::pduOutletSwitchedControlCommand.1.1  ( 100 i")
or if you wanted to use native format rather than strings, add the 'n' flag:
field(OUT,"@$(HOST) private $(MIB)::pduOutletSwitchedControlCommand.1.1  ( 100 in")
I'm assuming you're using my SNMP driver, which may be a mistake on my part because there are two other older ones out there.  But the documentation for mine is here:
From: Tech-talk <[email protected]> on behalf of White via Tech-talk <[email protected]>
Sent: Wednesday, March 20, 2024 4:20 AM
To: [email protected]
Subject: Control device via epics-snmp
[EXTERNAL] This email originated from outside of FRIB
Hi
I'm trying to control the device using the SNMP protocol. But I can caget to the value, when I caput, the value does not change.
the db file is as follows:
record(ao,"$(DEV):Switch1")
    field(DESC,"SNMP channel")
    field(DTYP,"Snmp")
    field(SCAN,"Passive")
    #field(PREC,"3")
    field(OUT,"@$(HOST) private $(MIB)::pduOutletSwitchedControlCommand.1.1  ( 100")
The mib file is as follows:
pduOutletSwitchedControlCommand OBJECT-TYPE
  -- FROM       ENLOGIC-PDU-MIB
  SYNTAX        INTEGER {immediateOff(1), immediateOn(2), delayedOff(3), delayedOn(4), immediateReboot(5), delayedReboot(6), outletUnknown(7)}
  MAX-ACCESS    read-write
  STATUS        current
  DESCRIPTION   "Getting this variable will return the outlet state.
                If the outlet is on, the immediateOn (2)
                value will be returned. If the outlet is off,
                the immediateOff (1) value will be returned. "
::= { iso(1) org(3) dod(6) internet(1) private(4) enterprises(1) enlogic(38446) pdu(1) pduOutlet(5) pduOutletSwitchedControlTable(5) pduOutletSwitchedControlEntry(1) pduOutletSwitchedControlCommand(4) 1 2 }
Is there an error somewhere in the db file?
Thanks
Control device via epics-snmp White via Tech-talk
Prev: RE: mcaAIM and nmcDemo not finding AIM 556 on new linux install Mark Rivers via Tech-talk
Next: PVXS IOC Philosophy Dave Bracey via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: Control device via epics-snmp White via Tech-talk
