1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Control device via epics-snmp
To: [email protected]
Date: Wed, 20 Mar 2024 16:20:22 +0800 (CST)
I'm trying to control the device using the SNMP protocol. But I can caget to the value, when I caput, the value does not change.
the db file is as follows:
record(ao,"$(DEV):Switch1")
    field(DESC,"SNMP channel")
    field(DTYP,"Snmp")
    field(SCAN,"Passive")
    #field(PREC,"3")
    field(OUT,"@$(HOST) private $(MIB)::pduOutletSwitchedControlCommand.1.1  ( 100")
The mib file is as follows:
pduOutletSwitchedControlCommand OBJECT-TYPE
  -- FROM       ENLOGIC-PDU-MIB
  SYNTAX        INTEGER {immediateOff(1), immediateOn(2), delayedOff(3), delayedOn(4), immediateReboot(5), delayedReboot(6), outletUnknown(7)}
  MAX-ACCESS    read-write
  STATUS        current
  DESCRIPTION   "Getting this variable will return the outlet state.
                If the outlet is on, the immediateOn (2)
                value will be returned. If the outlet is off,
                the immediateOff (1) value will be returned. "
::= { iso(1) org(3) dod(6) internet(1) private(4) enterprises(1) enlogic(38446) pdu(1) pduOutlet(5) pduOutletSwitchedControlTable(5) pduOutletSwitchedControlEntry(1) pduOutletSwitchedControlCommand(4) 1 2 }
Is there an error somewhere in the db file?
Thanks
Re: Control device via epics-snmp Priller, John via Tech-talk
Prev: ODP: Keysight oscilloscope DSOX1204 EPICS Driver Mateusz Nabywaniec via Tech-talk
Next: RE: mcaAIM and nmcDemo not finding AIM 556 on new linux install Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Archiver Appliance cluster deployment does not display identity of current node Wang, Lin via Tech-talk
Next: Re: Control device via epics-snmp Priller, John via Tech-talk
