1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: enable pvAccess by default
To: EPICS Tech Talk <[email protected]>
Date: Wed, 3 Apr 2024 01:29:25 -0700
I added this subject into an agenda for the upcoming Coderaton at BNL.
BTW, we (ALS-U) use our own template folder to generate our consistent IOC and application directory structure with additional scripts. That is the exact same workflow, which Ralph suggested.
However, from my view, we can just redesign (add a few lines, and change variables a bit) templates/makeBaseApp/top/iocApp/src/Makefile and iocBoot/st.cmd@Cross and st.cmd@common to support pvaccess easily.
Best,
Han
On Wed, Apr 3, 2024 at 12:30 AM Ralph Lange via Tech-talk <[email protected]> wrote:
Note that the template mechanism for makeBaseApp is specifically designed for users to add their own templates.
If you have five things you always need to add to the ioc template, create your own, starting from a copy of the ioc template. Most of the EPICS facilities I know and worked with have their own set of templates.
Cheers,
~Ralph
Jeong Han Lee, Dr.rer.nat.
Lawrence Berkeley National Laboratory
Re: enable pvAccess by default William Kirstaedter via Tech-talk
Re: enable pvAccess by default Johnson, Andrew N. via Tech-talk
Re: enable pvAccess by default Timo Korhonen via Tech-talk
Re: enable pvAccess by default Florian Feldbauer via Tech-talk
Re: enable pvAccess by default Ralph Lange via Tech-talk
Prev: PyDevice support compilation error Vishnu Patel via Tech-talk
Next: Re: enable pvAccess by default William Kirstaedter via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: Re: enable pvAccess by default Ralph Lange via Tech-talk
