1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Use of PUT https://localhost:8181/Olog/logs/multipart REST API for creating log entries with attachments
From: "Wang, Lin via Tech-talk" <[email protected]>
To: "Konrad Gajewski" <[email protected]>
Date: Tue, 9 Apr 2024 00:22:07 +0800 (GMT+08:00)
Hello Konrad,
You may need to replace the following line,
    {"id": str(uuid.uuid4()), "name": "FREIAlogo-v3_March19.png"}
with
    {"id": str(uuid.uuid4()), "filename": "FREIAlogo-v3_March19.png"}
which means the "filename" keyword rather than "name" keyword should be used.
Attached is the test code which can upload one file successfully in my test environment.
Lin
> -----原始邮件-----
> 发件人: "Konrad Gajewski via Tech-talk" <[email protected]>
> 发送时间:2024-04-08 19:51:29 (星期一)
> 收件人: "[email protected]" <[email protected]>
> 主题: [SPAM] Use of PUT https://urldefense.us/v3/__https://localhost:8181/Olog/logs/multipart__;!!G_uCfscf7eWS!ZWzrzroyYSbP9vfWkqeX932CPkasA0QSuJ0MFTQCpyUwqMaA3e8M3XWhhpiUrbgPnf00JJj9l7oi4sToNK8HVis$  REST API for creating log entries with attachments
> Hi,
> I'm trying to write a simple python program to create an entry in the
> new Olog server (API documented in
> https://urldefense.us/v3/__https://olog.readthedocs.io/en/latest/index.html__;!!G_uCfscf7eWS!dDgYNelpLq7ymQ7M1rIdPoepGvVQEAfQPCBtmSKeFTIOr5xieb6nu3QDLfhW7gWC1u9P52dP1-w0PfTS-T4BhX99ax7hhJoQQa75$  ).
> I am using PUT https://urldefense.us/v3/__https://localhost:8181/Olog/logs/multipart__;!!G_uCfscf7eWS!dDgYNelpLq7ymQ7M1rIdPoepGvVQEAfQPCBtmSKeFTIOr5xieb6nu3QDLfhW7gWC1u9P52dP1-w0PfTS-T4BhX99ax7hhOZ21DPF$  request and
> all works fine for entries without any attachments. If I try to add an
> attachment the entry itself is saved but saving the attachment fails.
> I have found pyOlog library but it seems to be the old version written
> for Glassfish and mysql architecture.
> Does anybody have a python library, or at least an example program
> showing how to use the new PUT
> https://urldefense.us/v3/__https://localhost:8181/Olog/logs/multipart__;!!G_uCfscf7eWS!dDgYNelpLq7ymQ7M1rIdPoepGvVQEAfQPCBtmSKeFTIOr5xieb6nu3QDLfhW7gWC1u9P52dP1-w0PfTS-T4BhX99ax7hhOZ21DPF$  API for creating the entries
> with an attachment.  A curl command showing the use of PUT
> https://urldefense.us/v3/__https://localhost:8181/Olog/logs/multipart__;!!G_uCfscf7eWS!dDgYNelpLq7ymQ7M1rIdPoepGvVQEAfQPCBtmSKeFTIOr5xieb6nu3QDLfhW7gWC1u9P52dP1-w0PfTS-T4BhX99ax7hhOZ21DPF$  would also be helpful.
> Below is the python code that I've used:
>      api_endpoint = "https://urldefense.us/v3/__https://olog-server:8181/Olog/logs/multipart__;!!G_uCfscf7eWS!dDgYNelpLq7ymQ7M1rIdPoepGvVQEAfQPCBtmSKeFTIOr5xieb6nu3QDLfhW7gWC1u9P52dP1-w0PfTS-T4BhX99ax7hhJIczIfa$ "
>      # Prepare log entry payload
>      log_entry = {
>          "owner": "dev",
>          "description": "New entry using Olog/logs/multipart with one
> attachment.\n",
>          "level": "INFO",
>          "title": "test4.py",
>          "logbooks": [{"name": "test"}],
>          "attachments":[
>      # Prepare the log entry payload as JSON
>      json_data = json.dumps(log_entry)
>      json_filename = json.dumps({"filename": "FREIAlogo-v3_March19.png"})
>      json_descr = json.dumps({"fileMetadataDescription": "image/png"})
>      # Prepare the multipart encoder
>      multipart_data = MultipartEncoder(
>          fields={
>              'logEntry': ('logEntry.json', json_data, 'application/json'),
>              'files': ('filename', json_filename, 'application/json'),
>              'files': ('fileMetadataDescription', json_descr,
>              'files': ('FREIAlogo-v3_March19.png',
> open('FREIAlogo-v3_March19.png', 'rb'), 'application/octet-stream')
>      # Set the Content-Type header with the boundary
>      headers = {
>          'Content-Type': multipart_data.content_type
>      try:
>          response = requests.put(api_endpoint, headers=headers,
> data=multipart_data, auth=HTTPBasicAuth(username, password))
>          if response.status_code == 200:
>              print("Log entry created successfully.")
>          else:
>              print("Failed to create log entry. Status code:
> {response.status_code}")
>      except Exception as e:
>          print("An error occurred: ",{str(e)})
> And a log from phoebus-olog server:
> 2024-04-08 13:28:42.337 DEBUG 1740 --- [nio-8181-exec-4]
> o.s.web.servlet.DispatcherServlet        : PUT "/Olog/logs/multipart",
> parameters={multipart}
> 2024-04-08 13:28:42.347 DEBUG 1740 --- [nio-8181-exec-4]
> s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped to
> org.phoebus.olog.LogResource#createLog(String, String, String, Log,
> MultipartFile[], Principal)
> 2024-04-08 13:28:42.349 DEBUG 1740 --- [nio-8181-exec-4]
> .m.m.a.RequestPartMethodArgumentResolver : Read "application/json" to
> [org.phoebus.olog.entity.Log@c517dec8]
> 2024-04-08 13:28:42.404  INFO 1740 --- [nio-8181-exec-4]
> org.phoebus.olog.LogResource             : Entry id 75 created from n/a
> 2024-04-08 13:28:42.406  WARN 1740 --- [nio-8181-exec-4]
> org.phoebus.olog.LogResource             : File FREIAlogo-v3_March19.png
> not matched with attachment meta-data
> 2024-04-08 13:28:42.407  INFO 1740 --- [nio-8181-exec-4]
> 2024-04-08 13:28:42.408 DEBUG 1740 --- [nio-8181-exec-4]
> m.m.a.RequestResponseBodyMethodProcessor : Using 'application/json',
> given [*/*] and supported [application/json, application/*+json,
> application/json, application/*+json]
> m.m.a.RequestResponseBodyMethodProcessor : Writing
> [org.phoebus.olog.entity.Log@ff3dfa85]
> 2024-04-08 13:28:42.410 DEBUG 1740 --- [nio-8181-exec-4]
> o.s.web.servlet.DispatcherServlet        : Completed 200 OK
> Best regards,
> Konrad
> Konrad Gajewski
> FREIA Laboratory
> https://urldefense.us/v3/__http://www.physics.uu.se/__;!!G_uCfscf7eWS!dDgYNelpLq7ymQ7M1rIdPoepGvVQEAfQPCBtmSKeFTIOr5xieb6nu3QDLfhW7gWC1u9P52dP1-w0PfTS-T4BhX99ax7hhPzk46FZ$
> När du har kontakt med oss på Uppsala universitet med e-post så innebär det att vi behandlar dina personuppgifter. För att läsa mer om hur vi gör det kan du läsa här: https://urldefense.us/v3/__http://www.uu.se/om-uu/dataskydd-personuppgifter/__;!!G_uCfscf7eWS!dDgYNelpLq7ymQ7M1rIdPoepGvVQEAfQPCBtmSKeFTIOr5xieb6nu3QDLfhW7gWC1u9P52dP1-w0PfTS-T4BhX99ax7hhEJJRf56$
> E-mailing Uppsala University means that we will process your personal data. For more information on how this is performed, please read here: https://urldefense.us/v3/__http://www.uu.se/en/about-uu/data-protection-policy__;!!G_uCfscf7eWS!dDgYNelpLq7ymQ7M1rIdPoepGvVQEAfQPCBtmSKeFTIOr5xieb6nu3QDLfhW7gWC1u9P52dP1-w0PfTS-T4BhX99ax7hhIzZpdTb$
Attachment: test2.py
Description: Binary data
Re: Use of PUT https://localhost:8181/Olog/logs/multipart REST API for creating log entries with attachments Konrad Gajewski via Tech-talk
Prev: Re: Use of PUT https://localhost:8181/Olog/logs/multipart REST API for creating log entries with attachments Shroff, Kunal via Tech-talk
Next: Check for write access in EPICS 7 Bellister, ,Jesse via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: Re: Use of PUT https://localhost:8181/Olog/logs/multipart REST API for creating log entries with attachments Konrad Gajewski via Tech-talk
