1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: get asyn hostInfo
From: Douglas Araujo via Tech-talk <[email protected]>
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 9 Apr 2024 08:08:08 +0000
Hi Mark,
I have identified the problem..
When I was obtaining the interface, I mistakenly used the wrong interfaceType (asynCommonType).
pasynInterface = pasynManager->findInterface(pasynUserOctet_, asynCommonType, 1);
To utilize the asynOption, the correct interfaceType should be asynOptionType:
pasynInterface = pasynManager->findInterface(pasynUserOctet_, asynOptionType, 1);
Now, I have successfully managed to read the option hostInfo.
Thank you for your assistance.
Douglas
From: Tech-talk <[email protected]> on behalf of Douglas Araujo via Tech-talk <[email protected]>
Sent: Thursday, April 4, 2024 5:40:33 PM
To: Mark Rivers
Cc: [email protected]
Hi Mark,
I did that before, it returns 3 (asynError). I added new "logs", and seems like the errorMessage updates after the getOption function.
asynStatus status = asynSuccess;
std::cout << "Error msg before getOpiton: " << pasynUserOctet_->errorMessage << std::endl;
status = pasynOption->getOption(asynOptionPvt, pasynUserOctet_, "hostInfo", hostbuff, 100 );
std::cout << "Status: " << status << std::endl;
std::cout << "Error msg after getOpiton: " << pasynUserOctet_->errorMessage << std::endl;
Status: 3
Error msg after getOpiton: 192.168.50.2:65535 UDP: Link already open!
Douglas
Sent: Thursday, April 4, 2024 5:11:58 PM
To: Douglas Araujo
It looks like you are not checking the status return of that call.  What does it return?  Please print out the return value.
You are printing the error message:
std::cout << pasynUserOctet_->errorMessage << std::endl;
regardless of the return value of that function.  That could be a stale error message.
Sent: Thursday, April 4, 2024 7:16 AM
Cc: [email protected] <[email protected]>
Oh, my apologies! I omitted part of the line...
The complete line is:
(gdb) p pasynOption
$6 = (asynOption *) 0x7ffff624fcd0 <drvAsynIPPortAsynCommon>
I assume that I am utilizing the following function:
Sent: Thursday, April 4, 2024 3:51:19 PM
To: Douglas Araujo
Hi Douglas,
In this line of code:
  •  getOption(asynOptionPvt, pasynUserOctet_, "hostInfo", hostbuff, 100 );
where is the getOption() function defined? Is that a function you wrote?  Because in asynRecord the code is this:
 pasynRecPvt->pasynOption->getOption(pasynRecPvt->asynOptionPvt, pasynUser,
Sent: Thursday, April 4, 2024 6:15 AM
Sure, perhaps I haven't made myself clear, but the code I included in the question is indeed mine. Now, I'm providing the specific block for clarity.
RMMRegisterAccess::RMMRegisterAccess(const std::string& address_info) {
  connect(address_info);
  asynInterface *pasynInterface;
  void *asynOptionPvt;
  asynOption *pasynOption;
  pasynOption = (asynOption *) pasynInterface->pinterface;
  asynOptionPvt = pasynInterface->drvPvt;
  char hostbuff[100];
asynStatus RMMRegisterAccess::connect(const std::string& address_info) {
// where address_info is the portName defined in the drvAsynIPPortConfigure
  return pasynOctetSyncIO->connect(address_info.c_str(), 0, &pasynUserOctet_, NULL);
Douglas
Sent: Thursday, April 4, 2024 2:59:14 PM
To: Douglas Araujo
Can you share your code?
Sent from my iPhone
On Apr 4, 2024, at 8:50 AM, Douglas Araujo <[email protected]> wrote:
Yes, I have confirmed that the value in theHOSTINFO asyn record field is correct:
$ pvget asyn:Test.HOSTINFO
asyn:Test.HOSTINFO <undefined>              "192.168.50.2:65535 UDP"
I also assumed that this should work, but for some reason, I am receiving the error:
So, I am wondering if the instance of pasynOption that I created is receiving the same pasynInterface value that was defined with drvAsynIPPortConfigure and is also being used in the asyn record code.
Douglas
Sent: Thursday, April 4, 2024 2:02:03 PM
To: [email protected]; Douglas Araujo
If you open the asynRecord OPI screen asynIPPortSetup does it correctly display the current IP host information in the widget labeled "Host info:"?  If so, then using the same code as in the asynRecord should work?
Sent: Thursday, April 4, 2024 2:48 AM
To: [email protected] <[email protected]>
Subject: get asyn hostInfo
Hi all,
Does anyone know how to read the hostInfo value that is passed into the  drvAsynIPPortConfigure function ?
Basically, I have this in my startup script:
epicsEnvSet("IPADDR", "192.168.50.2")
epicsEnvSet("IPPORT", "65535")
drvAsynIPPortConfigure("L0", "$(IPADDR):$(IPPORT) UDP", 0, 0, 1)
And in my c++ code:
status = pasynOctetSyncIO->connect(address_info.c_str(), 0, &pasynUserOctet_, NULL); // where address_info is the portName
So, I tried following the steps inside asynRecord.c:
char hostbuff[100];
But I received the message error:
Thanks in advance. -- Douglas Araujo
get asyn hostInfo Douglas Araujo via Tech-talk
Re: get asyn hostInfo Mark Rivers via Tech-talk
Re: get asyn hostInfo Douglas Araujo via Tech-talk
Prev: Re: Use of PUT https://localhost:8181/Olog/logs/multipart REST API for creating log entries with attachments Shroff, Kunal via Tech-talk
Next: Re: PyDevice support compilation error Vishnu Patel via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: Re: get asyn hostInfo Douglas Araujo via Tech-talk
Next: 2024 EPICS codeathon/documentathon Shroff, Kunal via Tech-talk
