1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: PyDevice support compilation error
From: Vishnu Patel via Tech-talk <[email protected]>
To: "Pearson, Matthew" <[email protected]>, "Tech Talk ([email protected])" <[email protected]>
Date: Tue, 9 Apr 2024 11:06:50 +0000
Thanks Matt,
It is done.
Sent: 03 April 2024 19:32
To: Vishnu Patel <[email protected]>; Tech Talk ([email protected]) <[email protected]>
Subject: RE: PyDevice support compilation error
This looks like the same error:
https://epics.anl.gov/tech-talk/2023/msg01349.php
Try commenting out the two problem lines.
Cheers,
Matt
From: Tech-talk <[email protected]> On Behalf Of Vishnu Patel via Tech-talk
Sent: Wednesday, April 3, 2024 4:23 AM
To: Tech Talk ([email protected]) <[email protected]>
Subject: [EXTERNAL] PyDevice support compilation error
    I am trying to compile PyDevice python device support on the Ubuntu Core over raspberry pi.  I am using epics base-7.0.1.1 and python 3.5.2
I am getting an error
Installing dbd file ../../dbd/pydev315.dbd
Installing dbd file ../../dbd/pycalcRecord.dbd
Installing generated generic include file ../../include/pycalcRecord.h
mkdir ../../include
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3 -g   -Wall     -I/usr/include/python3.5m -I/usr/include/python3.5m -std=c++11 -O2 -DUSE_TYPED_RSET       -fPIC -g -ggdb -O0 -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I../../../../base-7.0.1.1/include/compiler/gcc -I../../../../base-7.0.1.1/include/os/Linux -I../../../../base-7.0.1.1/include        -c ../asyncexec.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3 -g   -Wall     -I/usr/include/python3.5m -I/usr/include/python3.5m -std=c++11 -O2 -DUSE_TYPED_RSET       -fPIC -g -ggdb -O0 -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I../../../../base-7.0.1.1/include/compiler/gcc -I../../../../base-7.0.1.1/include/os/Linux -I../../../../base-7.0.1.1/include        -c ../epicsdevice.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX  -Dlinux     -O3 -g   -Wall     -I/usr/include/python3.5m -I/usr/include/python3.5m -std=c++11 -O2 -DUSE_TYPED_RSET       -fPIC -g -ggdb -O0 -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I../../../../base-7.0.1.1/include/compiler/gcc -I../../../../base-7.0.1.1/include/os/Linux -I../../../../base-7.0.1.1/include        -c ../pywrapper.cpp
../pywrapper.cpp:351:67: error: duplicate explicit instantiation of ‘static bool PyWrapper::exec(const string&, bool, T*) [with T = long long int; std::__cxx11::string = std::__cxx11::basic_string<char>]’ [-fpermissive]
 template bool PyWrapper::exec(const std::string&, bool, long long*);
../pywrapper.cpp:352:76: error: duplicate explicit instantiation of ‘static bool PyWrapper::exec(const string&, bool, T*) [with T = long long unsigned int; std::__cxx11::string = std::__cxx11::basic_string<char>]’ [-fpermissive]
 template bool PyWrapper::exec(const std::string&, bool, unsigned long long*);
../../../../base-7.0.1.1/configure/RULES_BUILD:237: recipe for target 'pywrapper.o' failed
make[2]: *** [pywrapper.o] Error 1
make[2]: Leaving directory '/home/vishnu.patel/epics/support/PyDevice/src/O.linux-arm'
../../../base-7.0.1.1/configure/RULES_ARCHS:58: recipe for target 'install.linux-arm' failed
make[1]: *** [install.linux-arm] Error 2
make[1]: Leaving directory '/home/vishnu.patel/epics/support/PyDevice/src'
../../base-7.0.1.1/configure/RULES_DIRS:84: recipe for target 'src.install' failed
make: *** [src.install] Error 2
Is any one have idea?
Thanks
Vishnu
PyDevice support compilation error Vishnu Patel via Tech-talk
RE: PyDevice support compilation error Pearson, Matthew via Tech-talk
Prev: Re: get asyn hostInfo Douglas Araujo via Tech-talk
Next: Re: urldefense.us URLs? (was: New Git mirror for the SNL-Sequencer (code and docs)) J. Lewis Muir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: RE: PyDevice support compilation error Pearson, Matthew via Tech-talk
Next: Pfeiffer Omnicontrol 200 Pierrick M Hanlet via Tech-talk
