1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Fw: Remote reset of MVME-2700 possible through serial console
From: Kevin Peterson via Tech-talk <[email protected]>
To: "Arnold, Ned D." <[email protected]>, "[email protected] >> EPICSTech Talk" <[email protected]>
Date: Mon, 15 Apr 2024 09:52:55 -0500
FYI for those new to VMEs & EPICS: how a VME is rebooted can affect whether or not autosaved positions are restored to the motor records for OMS cards (VME58 & MAXv).
Hard rebooting a VME's CPU (power-cycle, physical reset button, doodle board & ctrl+y*3) resets the OMS controller's motor positions to zero, which usually results in the restoration of autosaved motor positions.
Soft rebooting a VME's CPU (ctrl+x) does NOT reset the OMS controller's motor positions, which usually results in the restoration for autosaved motor positions for only the motors that have sufficiently non-zero positions (>RDBD), assuming the RSTM field hasn't been changed.
Kevin
On 4/12/24 19:38, Arnold, Ned D. via Tech-talk wrote:
*Sent:* Friday, April 12, 2024 07:38 PM
*To:* Maren Purves <[email protected]>
*Subject:* Re: Remote reset of MVME-2700 possible through serial console
 >> every board I ever had to boot remotely would reboot with a ^x
This is very different than generating a VME bus RESET ... like the doodle board Mark mentioned does.  We (APS) have found it invaluable to be able to generate a hard VME Reset through the doodle board. Otherwise, techs would be called in to cycle the power (2 hour delay).
   Ned
Remote reset of MVME-2700 possible through serial console Jennings, Guy via Tech-talk
Re: Remote reset of MVME-2700 possible through serial console Maren Purves via Tech-talk
Fw: Remote reset of MVME-2700 possible through serial console Arnold, Ned D. via Tech-talk
Prev: Re: Readback of output variables in adsDriver Jure Varlec via Tech-talk
Next: AW: Readback of output variables in adsDriver Meyer, Markus via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Fw: Remote reset of MVME-2700 possible through serial console Arnold, Ned D. via Tech-talk
Next: Example of using a record field from an external IOC as an INPA link on a calcout record Wlodek, Jakub via Tech-talk
