1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: EPICS sometimes disconnect when I moving motor
From: whitetiger1123 via Tech-talk <[email protected]>
Date: Tue, 23 Apr 2024 16:07:45 +0900
We are currently using Altekna's watt pilot and controller. In order to use this in epics, we made python code to communicate with epics, and we checked it works.
But here we got a problem. If we move the motor often, epics will have a problem where it accepts and does not accept commands. For example, if you move the motor often, epics will be disconnected, and you have to manually turn the controller off and then run Python code to run epics again.
Can anyone solve this problem? I want to know what kind of problem it is.
EPICS Base : R3.16.1
OS : NAME="Rocky Linux"
VERSION="8.8 (Green Obsidian)"
Linux version 4.18.0-477.27.1.el8_8.x86_64 (gcc version 8.5.0 20210514 (Red Hat 8.5.0-18)
PS. I’m also attaching the code.
https://github.com/whitetiger112233/watt
This is my GitHub, you guys can watch about my python code.
Please anyone watch and give me some advice..
Sincerely,
Baeg
Re: (caproto) EPICS sometimes disconnect when I moving motor Michael Davidsaver via Tech-talk
Prev: RE: Disable output record using asynInt32 interface automatic read from the hardware Mark Rivers via Tech-talk
Next: AMI 286 Liquid Level Controller Tran, Phi Dung via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: Re: (caproto) EPICS sometimes disconnect when I moving motor Michael Davidsaver via Tech-talk
