1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: AMI 286 Liquid Level Controller
From: "Tran, Phi Dung via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 23 Apr 2024 12:46:49 +0000
I have an IOC that operates with the controller. However, whenever there is a power outage, the controller starts flashing, and the IOC loses communication with it via RS232. To temporarily resolve this issue, I unplug the RS232 cable from the IOC and then plug it back in. This action resets the controller, and the IOC resumes proper communication.
If you have encountered a similar problem, I would appreciate any suggestions.
Thank you,
Alex Tran
Re: AMI 286 Liquid Level Controller Tynan Ford via Tech-talk
Prev: EPICS sometimes disconnect when I moving motor whitetiger1123 via Tech-talk
Next: Editing .pb files for the purpose of appending data to them Windsor Tanner via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Prev: Re: (caproto) EPICS sometimes disconnect when I moving motor Michael Davidsaver via Tech-talk
Next: Re: AMI 286 Liquid Level Controller Tynan Ford via Tech-talk
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
