Hi Alex,
We have the AMI 136 and 186 models using the IEEE-488 GPIB option instead of RS232. With GPIB we saw similar issues and found that reboots of the Agilent E2050 GPIB ethernet gateway were needed to restore IOC communication. We tried using an ICS GPIB ethernet gateway and could not get any communication working (SRQ line wouldn't clear).
In the end we decided to use the 0-10V analog interface on the J2 connector instead of GPIB.
Best Regards, Tynan
On Tue, Apr 23, 2024 at 5:47 AM Tran, Phi Dung via Tech-talk < [email protected]> wrote:
I have an IOC that operates with the controller. However, whenever there is a power outage, the controller starts flashing, and the IOC loses communication with it via RS232. To temporarily resolve this issue, I unplug the RS232 cable from the IOC and then
plug it back in. This action resets the controller, and the IOC resumes proper communication.
If you have encountered a similar problem, I would appreciate any suggestions.
Thank you,
Alex Tran
- Re: AMI 286 Liquid Level Controller Tran, Phi Dung via Tech-talk
- AMI 286 Liquid Level Controller Tran, Phi Dung via Tech-talk
Re: (caproto) EPICS sometimes disconnect when I moving motor Michael Davidsaver via Tech-talk
Re: Editing .pb files for the purpose of appending data to them Sky Brewer via Tech-talk
<2024>
2025
2026
<2024>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
