1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: AMI 286 Liquid Level Controller
From: "Tran, Phi Dung via Tech-talk" <[email protected]>
To: Tynan Ford <[email protected]>
Date: Fri, 26 Apr 2024 16:46:05 +0000
Hi Tynan,
My AMI 286 LLC is connected to a Moxa Switch. I discovered that by setting the Data Packing delimiter 1 hex value to 0A for Line Feed, the controller could recover after a power shutdown. Now I understand how, but I'm still uncertain about the underlying reason.
Sincerely,
Alex Tran
Sent: Tuesday, April 23, 2024 1:52 PM
To: Tran, Phi Dung <[email protected]>
Cc: [email protected] <[email protected]>
Hi Alex,
We have the AMI 136 and 186 models using the IEEE-488 GPIB option instead of RS232. With GPIB we saw similar issues and found that reboots of the Agilent E2050 GPIB ethernet gateway were needed to restore IOC communication. We tried using an ICS GPIB ethernet gateway and could not get any communication working (SRQ line wouldn't clear).
In the end we decided to use the 0-10V analog interface on the J2 connector instead of GPIB.
Best Regards,
Tynan
On Tue, Apr 23, 2024 at 5:47 AM Tran, Phi Dung via Tech-talk <[email protected]> wrote:
I have an IOC that operates with the controller. However, whenever there is a power outage, the controller starts flashing, and the IOC loses communication with it via RS232. To temporarily resolve this issue, I unplug the RS232 cable from the IOC and then plug it back in. This action resets the controller, and the IOC resumes proper communication.
If you have encountered a similar problem, I would appreciate any suggestions.
Thank you,
Alex Tran
Attachment: moxaAmi.png
Description: moxaAmi.png
AMI 286 Liquid Level Controller Tran, Phi Dung via Tech-talk
Re: AMI 286 Liquid Level Controller Tynan Ford via Tech-talk
Prev: Job Opportunities at the Canadian Light Source Gillian Black via Tech-talk
Next: Question about PV value from epics ioc neu lzf via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: Re: AMI 286 Liquid Level Controller Tynan Ford via Tech-talk
Next: Editing .pb files for the purpose of appending data to them Windsor Tanner via Tech-talk
