1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: CryoTel GT Cooler: different startup and shutdown StreamDevice protocols
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Thu, 23 May 2024 22:19:50 +0200
On Thu, 23 May 2024 at 21:19, boj via Tech-talk <[email protected]> wrote:
I need to send one of the following commands:
SET SSTOP=1
or
SET SSTOP=0
However, the response is different in the two cases.
I think a "BO" record, should be used, but is there anyway I can have
different protocol definitions for the "1" and "0" state?
Alternatively, is there an easy way to separate this into two records?
I would just map the behaviour:
Create two protocols for on and off, with hardcoded values and command-specific replies.
Use two bo records, push-button style, HIGH=0.1, and connect them to the two protocols.
If you need a switch instead of two push-buttons, add another bo for the switch, FLNKing to a seq record in SELM=specified mode that writes a 1 to the appropriate push-button.
Cheers,
~Ralph
Re: CryoTel GT Cooler: different startup and shutdown StreamDevice protocols boj via Tech-talk
Prev: CryoTel GT Cooler: different startup and shutdown StreamDevice protocols boj via Tech-talk
Next: Re: CryoTel GT Cooler: different startup and shutdown StreamDevice protocols Zimoch Dirk via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Next: Re: CryoTel GT Cooler: different startup and shutdown StreamDevice protocols boj via Tech-talk
