1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: CryoTel GT Cooler: different startup and shutdown StreamDevice protocols
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 23 May 2024 21:19:19 +0200
Dear all
I am implementing a StreamDevice based IOC for a "CryoTel GT Cooler", which in general is very easy to communicate with, but has some strange behaviors for
the startup and shutdown commands.
I need to send one of the following commands:
SET SSTOP=1
or
SET SSTOP=0
However, the response is different in the two cases.
I think a "BO" record, should be used, but is there anyway I can have different protocol definitions for the "1" and "0" state?
Alternatively, is there an easy way to separate this into two records?
Thanks in advance
    Bo
Re: CryoTel GT Cooler: different startup and shutdown StreamDevice protocols Ralph Lange via Tech-talk
Prev: RE: Changing runtime limits with Channel Access Alessandra Palazzo via Tech-talk
Next: Re: CryoTel GT Cooler: different startup and shutdown StreamDevice protocols Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Prev: Re: JavaFX Phoebus warning at run time Kasemir, Kay via Tech-talk
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
