1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Re: JavaFX Phoebus warning at run time
From: "Kasemir, Kay via Tech-talk" <tech-talk at aps.anl.gov>
To: William F Badgett Jr <badgett at fnal.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 21 May 2024 13:16:57 +0000
In short, it’s a warning that you can ignore.
In more detail, software tends to be split into what’s called  libraries or modules or packages or … depending on the programming language.
For Java, the basic unit has been and continues to be “jar” files (Java ARchive files, basically ZIP files).
That’s what we use.
From Java version 9 on, there is the new option of using “module” files. The maintainers of the JavaFX graphics library package their stuff in the form of a jar that can also be used as a module file, and as you can see from the warning, they suggest that everybody starts moving from jar to module files, but at this time I’m not sure there’s any advantage in doing that except for avoiding that warning. On the contrary, I’m quite sure that we rely on many libraries that are plain jars and not modules. While a pure module-based setup might at some point become a good idea because it adds some form of dependency hierarchy support, I don’t see right now as the best time to do that.
Cheers,
Kay
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of William F Badgett Jr via Tech-talk <tech-talk at aps.anl.gov>
Date: Monday, May 20, 2024 at 11:42
AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: [EXTERNAL] JavaFX Phoebus warning at run time
When launching a locally build Phoebus 4.7.3 using JDK 21.0.3 on Alma Linux 9, we get a warning
about JavaFX at Phoebus launch time:
2024-05-17 14:56:29 WARNING [javafx] Unsupported JavaFX configuration: classes were loaded from 'unnamed module @5e6622f5'
Is there a suggested remedy?
thanks
William Badgett
Accelerator Division Controls
Fermi National Accelerator Lab
Kirk and Wilson Roads, MS 360
BTE-214 Booster Tower East Room 214
Batavia, IL 60510 U.S.A.
badgett at fnal.gov
JavaFX Phoebus warning at run time William F Badgett Jr via Tech-talk
Prev: JavaFX Phoebus warning at run time William F Badgett Jr via Tech-talk
Next: RE: Changing runtime limits with Channel Access Alessandra Palazzo via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Next: CryoTel GT Cooler: different startup and shutdown StreamDevice protocols boj via Tech-talk
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
