1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: CA Lab V1.7.3.3 released (LabVIEW / EPICS interface)
From: Carsten Winkler via Tech-talk <[email protected]>
Date: Mon, 10 Jun 2024 12:11:49 +0200
We are pleased to share the latest release of CA Lab, V1.7.3.3!
This update introduces several enhancements and fixes.
Key Updates and Enhancements:
  • Formatted String Results: When you query the PREC field, the string output is now neatly formatted in CaLabGet.vi. This applies to EPICS records that support the PREC field, ensuring accuracy in your data.
  • Detailed EPICS Information: The PVList in CaLabInfo.vi now displays both the EPICS record type and the native EPICS data type, giving you more comprehensive information at a glance.
  • New Utilities for Palette Management: We've added utility VIs to easily add or remove CA Lab from the palette set in LabVIEW, offering greater flexibility in how you manage your tools.
Updates and Fixes:
  • Input Label Clarification: To avoid any confusion with programming terminology, we've changed the input label "synchronous" to "wait" in caLabPut.vi. This update maintains full backward compatibility.
  • Bug Fixes and Improvements:
    • Resolved the 39-character string bug, ensuring smoother performance.
    • Fixed issues with 64-bit record handling for large numbers, improving stability.
    • Addressed problems with data type conversion, especially for inactive EPICS variables at the program start.
  • SoftIOC Demo.vi Enhancements: Made minor improvements to enhance your demonstration experience.
  • Simplified Setup: The setup process no longer requires admin rights, making installation more straightforward and accessible.
  • Updated Storage Location: CA Lab libraries and VIs are now saved under %APPDATA%\calab, aligning with modern application standards for better data management.
We believe these updates will significantly improve your workflow and provide a more robust toolset for your projects. Your feedback has been invaluable in guiding these improvements, and we appreciate your continued support.
Stay tuned for more updates and happy coding!
https://github.com/epics-extensions/CALab/releases
https://www.helmholtz-berlin.de/zentrum/organisation/it/calab/index_en.html
Best regards,
Carsten Winkler
Prev: What is the use case of org.phoebus.pv.PV.onAccessRightsEvent().subscribe() Wang, Lin via Tech-talk
Next: Re: [EXTERNAL] What is the use case of org.phoebus.pv.PV.onAccessRightsEvent().subscribe() Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: Re: [EXTERNAL] What is the use case of org.phoebus.pv.PV.onAccessRightsEvent().subscribe() Ralph Lange via Tech-talk
Next: epics build system question again - build order William Kirstaedter via Tech-talk
