Dear all, I saw the following code snippet to monitor the PV access right in Phoebus and also similar things in pvws, writable_flow = pv.onAccessRightsEvent() .subscribe(this::writableChanged); As I understand, the access right of an IOC or an CA gateway is determined by the Access Security Configuration File when started, and the access right can be obtained by the following code, /** @return <code>true</code> if PV is read-only */ public boolean isReadonly() { return pv.isReadonly(); }
Thanks, Lin
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
