1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Re: [External] RE: Building EPICS 7
From: John Dong via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech-Talk <tech-talk at aps.anl.gov>
Date: Tue, 18 Jun 2024 06:47:46 -0400
Guys,
I want to thank you for your quick assistance.  The last EPICS build I did was before 2000.
jd
On Tue, Jun 18, 2024 at 6:43 AM John Dong <jdong at pppl.gov> wrote:
Hi Ralph,
My environment variables:
I was following the attached instructions.  I will try the one you suggested.
jd
On Tue, Jun 18, 2024 at 6:37 AM Ralph Lange via Tech-talk <tech-talk at aps.anl.gov> wrote:
On Tue, 18 Jun 2024 at 12:28, John Dong via Tech-talk <tech-talk at aps.anl.gov> wrote:
I am using Strawberry Perl so I built with mingw.
This is the error:
process_begin: CreateProcess(NULL, cl -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I../osi/compiler/msvc -
That's the command line for the Microsoft compiler (MSVC).
Your EPICS_HOST_ARCH seems to be configured for the wrong toolchain.
Do you have any particular reason to not follow the Windows instructions at
Cheers,
~Ralph
Building EPICS 7 John Dong via Tech-talk
RE: Building EPICS 7 Freddie Akeroyd - STFC UKRI via Tech-talk
Re: [External] RE: Building EPICS 7 John Dong via Tech-talk
Re: [External] RE: Building EPICS 7 Ralph Lange via Tech-talk
Prev: RE: [External] RE: Building EPICS 7 Freddie Akeroyd - STFC UKRI via Tech-talk
Next: Re: [External] RE: Building EPICS 7 Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Prev: Re: [External] RE: Building EPICS 7 Ralph Lange via Tech-talk
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
