Hi Jörn,
On 6/19/24 05:47, Jörn Dreyer via Tech-talk wrote:
Hi Ralph,
after some more thinking and investigation, I found a more propper fix for the problem. If one adds the following two lines to
base/configure/os/CONFIG_SITE.linux-x86_64.UnixCommon
CFLAGS += -D_FORTIFY_SOURCE=2
CXXFLAGS += -D_FORTIFY_SOURCE=2
the code gets compiled with the old setting of _FORTIFY_SOURCE. Thats only a temporary fix of course. Clearly the code should be fixed for this errors.
I think this is reasonable. I have an unpleasant suspicion that
we will be seeing with these "errors" for some time.
It took me awhile to understand that:
*** buffer overflow detected ***: terminated
should actually be understood as "buffer overflow predicted".
And this is in all likelihood a false positive.
If you can, it would be helpful if you could gather some more
information to help us reproduce this fault. Either by finding
a reduced test case which triggers the fault, or in probing further
with debug prints. (As far as I can tell, the extra information
used by the fortify checks in not available to the debugger)
The stack trace you shows that access is to a ENUM or MENU field
of an aiRecord. Which field?
The trace points to the strncpy() at dbAccess.c:192 .
(which interestingly seems to be compiled into a plain strcpy() )
https://urldefense.us/v3/__https://github.com/epics-base/epics-base/blob/772c10d904c2c149ce2154996091858514f27265/modules/database/src/ioc/db/dbAccess.c*L192__;Iw!!G_uCfscf7eWS!Yp-ntUckX3N6O8iHjWlGFPCp1L9RPDJG24HtOKaNMNroby7MnOeAdw-CqP-1vx-kISxEFyPDM0pgiaBGES1Dz6LGIw$
Could you try applying the attached patch, which adds some debug prints?
I see something like the following. All of the 'f's mean that GCC
is unable to track the sizes of the objects involved. I also don't
see a fault.
X test.LINR ptemp=ffffffffffffffff,ffffffffffffffff papChoice=ffffffffffffffff,ffffffffffffffff i=0
diff --git a/modules/database/src/ioc/db/dbAccess.c b/modules/database/src/ioc/db/dbAccess.c
index c9d39c57c..1b55aabbf 100644
--- a/modules/database/src/ioc/db/dbAccess.c
+++ b/modules/database/src/ioc/db/dbAccess.c
@@ -191,6 +191,13 @@ choice_common:
for (i=0; i<no_str; i++) {
if(papChoice[i]==NULL) *ptemp=0;
else {
+ fprintf(stderr, "X %s.%s ptemp=%zx,%zx papChoice=%zx,%zx i=%u\n",
+ paddr->precord->name, paddr->pfldDes->name,
+ __builtin_dynamic_object_size(ptemp, 0),
+ __builtin_dynamic_object_size(ptemp, 1),
+ __builtin_dynamic_object_size(papChoice, 0),
+ __builtin_dynamic_object_size(papChoice, 1),
+ i);
strncpy(ptemp,papChoice[i],
sizeof(pdbr_enumStrs->strs[0]));
*(ptemp+sizeof(pdbr_enumStrs->strs[0])-1) = 0;
- Re: Strange problem with EPICS areaDetector Michael Davidsaver via Tech-talk
- Strange problem with EPICS areaDetector Jörn Dreyer via Tech-talk
- Re: Strange problem with EPICS areaDetector Ralph Lange via Tech-talk
- Re: Strange problem with EPICS areaDetector Jörn Dreyer via Tech-talk
Re: IOC connection problem Johnson, Andrew N. via Tech-talk
<2024>
2025
<2024>
2025
