1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: areaDetector Overlay problem
To: EPICS Talk <[email protected]>, Jörn Dreyer <[email protected]>
Date: Thu, 5 Sep 2024 12:47:37 +0000
Hi Jörn,
  • Shouldn't the overlay plugin add another image to the output att a defined address (5 in this case)?
No, the plugin does not use different addresses for the output for each overlay (1-8).  It always uses address 0.
Each overlay (1-8) is independent and the output image contains all of those overlays that are enabled, so you could have both a cursor and text, for example.
Since you are not seeing the overlay when you use address 0, that could be because of the following:
  • The NDPluginOverlay itself is not enabled.  You must enable both the overlay plugin and the specific overlays (1-8) that you want.
  • The color of the overlay is not set to a very visible color.
  • The width is set too small.  If the width is 1 and you are using a viewer that downsizes the original image for your screen that can result in some pixels not being displayed at all.  Try increasing the width to 3, for example.
Please send a screenshot of NDOverlayN or NDOverlay8 so we can see how you have defined the overlay features.
From: Tech-talk <[email protected]> on behalf of Jörn Dreyer via Tech-talk <[email protected]>
Sent: Thursday, September 5, 2024 2:22 AM
Subject: areaDetector Overlay problem
currently I have a problem to get the overlay plugin working. I would like to draw a cursor onto my image.
I have an ADBase set up with an asynPort "cam1". I connect an Overlay plugin "OVER1" to the output of this asynPort with asyn address set to 0.
I defined the cursor "CURSOR1" at NDOverlay8 line 5 and enabled it.
An NDStdArray is connected to asynPort "OVER1".
And here the problem starts. If I set the asyn address to 0, I see the original image from the camera.
If I set it to 1...X nothing happens. No more images are seen.
Or did I understand the functionality of plugins completely wrong?
Any help appreciated.
Joern
areaDetector Overlay problem Jörn Dreyer via Tech-talk
Prev: Re: Asyn or Stream device interface for struct data Zimoch Dirk via Tech-talk
Next: Adding additional fields to be archived in "policies.py" Windsor Tanner via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: areaDetector Overlay problem Jörn Dreyer via Tech-talk
Next: Asyn or Stream device interface for struct data Abdalla Ahmad via Tech-talk
