1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Help with rtems nfs mounting
From: "Knap, Giles \(DLSLtd,RAL,LSCI\) via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Miceli, Antonino" <[email protected]>
Cc: "Malowany, Alex \(DLSLtd,RAL,LSCI\)" <[email protected]>
Date: Fri, 6 Sep 2024 21:15:56 +0000
I can't help with the debugging but I have made RTEMS5 and 6 connect to NFSv2 using a user space NFSv2 driver running on RHEL8.
At DLS we are still running RHEL 7 to serve NFSv2 to our VxWorks and RTEMS IOCs. However we have been looking to retire those servers.
I have had success with the user space NFSv2 running in a container in Kubernetes. However you could also try compiling the driver natively using the steps in the Dockerfile. See epics-containers/nfsv2-tftp-server: User space NFSv2 and TFTP server for experimenting with RTEMS booting (github.com)
Copying Alex: as you were planning to test switching on NFSv2 on RHEL8 I thought you might be interested to hear that there may be issues.
Cheers,
giles
From: Tech-talk <[email protected]> on behalf of Miceli, Antonino via Tech-talk <[email protected]>
Sent: 06 September 2024 21:27
To: [email protected] <[email protected]>
Subject: Help with rtems nfs mounting
I have some legacy rtems IOCs. I can't get the NFS mount to work after our IT upgraded to RHEL9. So, they setup an RHEL8 VM with nfs v2 activated.  They say it is working:
[root@dplab ~]# mount -o vers=2 rtems-dserv:/xorApps  /mnt
[root@dplab ~]# mount | grep mnt
rtems-dserv:/xorApps on /mnt type nfs (rw,vers=2,addr=10.54.100.9)
But not of the IOC below....
Any advices on debugging this?
B$ printenv
FACTORY=Arcturus Networks Inc.
REVISION=uC5282-16E16C64
SERIAL=X4CB88918-01660
CONSOLE=ttyS0
KERNEL=0:linux.bin
KERNEL_ARGS=root=/dev/mtdblock0 quiet
HWADDR0=00:06:3b:01:36:60
FW_VERSION=010809000
RAMIMAGE=yes
CACHE=on
_0=10000000:400000:RW
BOOTFILE=/xorApps/epics/synApps_5_3/ioc/dth/bin/RTEMS-uC5282/dthApp.boot
CMDLINE=/xorApps/epics/synApps_5_3/ioc/dth/iocBoot/iocdth3/st.rtems.cmd
NETMASK=255.255.255.0
AUTOBOOT=20
HOSTNAME=iocdth3
IPADDR0=10.54.112.70
GATEWAY=10.54.112.1
NAMESERVER=10.54.100.9
SERVER=10.54.100.9
NTPSERVER=10.54.100.9
NFSMOUNT=10.54.100.9:/xorApps:/xorApps
B$ go!
go!: command not found
B$ go
Copy...done
go! 0x40000
***** Initializing network *****
Startup after Software reset.
fs1: Ethernet address: 00:06:3b:01:36:60
***** Initializing NFS *****
This is RTEMS-RPCIOD Release $Name: rtems-addon-packages-4-7-1 $
($Id: rpcio.c,v 1.4 2006/08/30 13:52:10 joel Exp $)
Till Straumann, Stanford/SLAC/SSRL 2002
See LICENSE file for licensing info
This is RTEMS-NFS Release $Name: rtems-addon-packages-4-7-1 $
($Id: nfs.c,v 1.3 2006/06/20 00:36:25 ericn Exp $)
Trying to mount 10.54.100.9:/xorApps on /xorApps
RPCIO: server '10.54.100.9' not responding - still trying
***** Initializing NTP *****
    *************** WARNING ***************
    ***** NO RESPONSE FROM NTP SERVER *****
    *****  TIME SET TO DEFAULT VALUE  *****
***** Starting EPICS application *****
# RTEMS startup file for the uCDIMM
# NFS mount external file systems
< ../nfsCommands
#nfsMount s100dserv.xray.aps.anl.gov /APSshare /APSshare
nfsMount rtems-dserv.xray.aps.anl.gov /APSshare /APSshare
nfsMount: host 'rtems-dserv.xray.aps.anl.gov' not found
Nino
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd.
Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom.
Re: Help with rtems nfs mounting Johnson, Andrew N. via Tech-talk
Help with rtems nfs mounting Miceli, Antonino via Tech-talk
Prev: Help with rtems nfs mounting Miceli, Antonino via Tech-talk
Next: Re: Help with rtems nfs mounting Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
